Old 02-02-2019, 09:18 AM   #1
jw hash
jw hash's Avatar
Default tires
when I was at Turlock, there a guy selling European made Good Year tires. they are about half the price as the US made. I know they will not cut it for fine point. but they might be OK for a driver. has anyone tried these tires.
jw hash is offline   Reply With Quote
Old 02-02-2019, 12:26 PM   #2
katy
katy's Avatar
Default Re: tires
When I was in Romania a few years ago the bus had Good Year tires made in Egypt.
Old 02-02-2019, 03:01 PM   #3
Synchro909
Synchro909's Avatar
Default Re: tires
I'd do as you are before I bought those tyres - let some one else find out if they're any good. A few years back, no one could buy a decent tube - remember? The worst of those were made in the EEC using recycled materials. Once bitten............
On the other hand, just because it is made outside the US dosn't mean it's bad. Look who invented the car in the first place - and the radial tyre etc etc.
I'll follow this thread.
Old 02-02-2019, 07:36 PM   #4
updraught
updraught's Avatar
Default Re: tires
They are probably made at the Sava factory in Slovenia.
Their 4wd tires survive the outback just fine.
https://www.sava-tires.com/sava/emea...us/who-we-are/
Nice country Slovenia.
updraught is offline   Reply With Quote
Old 02-02-2019, 08:27 PM   #5
Jeff/Illinois
Jeff/Illinois's Avatar
Default Re: tires
Synchro, are today's inner tubes quite a bit better than say 10-15 years ago?? Bratton's advertises freshly made tubes with fresh materials. Are these trustworthy??
Signed, nervous to buy new inner tubes hanging onto the old
Old 02-02-2019, 08:37 PM   #6
western77
western77's Avatar
Default Re: tires
The Goodyear tires on my 2014 f-150 are made in Chile. Work fine with 60000 on them
western77 is offline   Reply With Quote
Old 02-02-2019, 11:46 PM   #7
Synchro909
Synchro909's Avatar
Default Re: tires
I've run a few tubes that were made after Brattons started making theirs from new materials. I think others HAD to do the same or be left behind. I had to but others becasuse Brattons won't sell to Australiabut I've had good results. If you are nervous, dip your toe in the water by buying one or two as a trial.
If they withstand those conditions, they are pretty good.
Old 02-02-2019, 11:49 PM   #8
160B
160B's Avatar
Default Re: tires
I went through the process of getting new tubes in August of 2017 and ended up getting tubes from Bert’s Model A. Other vendors tubes had the valve stem off center and I did not want to use them.
see attached photo of tube with off center valve stem, same tube rotated 180 degrees to show offset. The third photo is the tubes I finally purchased note the on center valve stem.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
