05-24-2017, 08:16 AM | #1 |
back up lights
has anybody ever tried to install backup lights on an A??
Tinkirk/Terry |
05-24-2017, 08:30 AM | #2 |
Re: back up lights
No, but I found recently a small backup light purchase from one of the suppliers in the 80s and never installed.
Installation should be relatively simple if only providing power through an on-off switch.
Bob |
05-24-2017, 08:39 AM | #3 |
Re: back up lights
I don't want to know where you go at night and how you park that you would need back up lights .
, My daddy asking about 1972 ,. ,.
Sometimes I want to say ,,You should have bought a Shay. |
05-24-2017, 09:01 AM | #4 |
Re: back up lights
I mounted one on my 31 AA just aft of the pumpkin. Tough to see when reversing in the dark but it work wonders now. Trouble was finding a 3.5" 6 volt lamp to fit the housing I had. A local tractor supply brought one in for me. I mounted a fused switch top of the drivers kick panel with an red light indicator to tell me its on.
05-24-2017, 09:44 AM | #5 |
Re: back up lights
I have stock yellow brake lights. I was driving down a 4 lane road, with traffic lite's thru federal way wash., when so young guy in a ratty old el Camino pulled up and said "every time you brake, your back up lights come on." I just smiled and thanked him.
05-24-2017, 10:42 AM | #6 |
Re: back up lights
have not looked at the shifting part of it yet to see where i can install a switch Tinkirk/Terry |
05-24-2017, 11:02 AM | #7 |
Re: back up lights
Model A's are supposed to be driven forward ...
05-24-2017, 11:16 AM | #8 |
Re: back up lights
have one that resembles a small fog lamp mounted on the rear bumper bracket and operated by a toggle switch
05-24-2017, 11:41 AM | #9 |
Re: back up lights
FYI gotta watch some states - once you add a feature (turn signals, backup lights, seatbelts, etc) not originally from the factory you must abide by current laws and vehicle codes(IE burned out bulbs, not using turn signals, seat belt laws)
I think backup lights and maybe a soft beeper on an AA is a great idea. A hidden switch with a warning light/beeper that they are on is the simplest idea as well.
05-24-2017, 12:07 PM | #10 | |
Re: back up lights
Yep, thats part of the reason why I switched to all red. |
05-24-2017, 12:08 PM | #11 |
Re: back up lights
05-24-2017, 12:34 PM | #12 |
Re: back up lights
Seems like a good idea,the shift tower is set up so the detent rod for reverse would activate a switch screwed into the end of the casting.
Seems like I have a distant memory of some automatic trans with such a switch on them, maybe a Chrysler TF-6 or TF-8 ,,,,or some ancient cast iron thing? |
05-24-2017, 12:37 PM | #13 | |
Re: back up lights
05-24-2017, 12:59 PM | #14 |
Re: back up lights
05-24-2017, 12:59 PM | #15 |
Re: back up lights
that is kind of my thoughts just need to find the right spot to drill and tap an access hole
Tinkirk/Terry |
05-24-2017, 01:34 PM | #16 |
Re: back up lights
05-24-2017, 02:23 PM | #17 |
Re: back up lights
I have back-up lights installed on my pickup. They come on when the transmission is in reverse and the key is on.
Transmission is an RTS 3+OD, already supports back-up lights. The light fixtures were purchased on eBay.
05-24-2017, 03:59 PM | #18 |
Re: back up lights
manual trans S10's and blazers of all years work (82-05). 2 wire switch - grab the connector and as much wire as you can.
05-24-2017, 04:22 PM | #19 |
Re: back up lights
My grandma said she could not follow find reverse in her T and just parked it so she didn't need reverse :-)
05-24-2017, 05:12 PM | #20 |
Re: back up lights
FYI when I back up I turn my head lights off, it helps, and if you ride the brakes the extra red light helps!
FYI turning your dash lights down also help to see the road! Ask my brother, he was complaining one night that he couldn't see well. I asked him if he could turn his dash lights down, he did and he said wow i can see better! He then said how I knew that, why would they put a dimmer on dash lights, to see better at night!
