Go Back   The Ford Barn > The Swap Meet > Wanted > Model-A
Old 09-07-2023, 06:05 PM   #1
clifforddward
clifforddward's Avatar
Default Looking for A-3520F Steering Column Support Bracket
City: Cary
State: NC
Looking for the longer steering column support bracket used on 190-A Victorias and several other special models...part number stamped in underside of part is A-3520F (Note it is the "F" that designates this particular longer version). Bracket length is approximately 8 1/2" end-to-end not including the clamping part that goes around steering column. This part came in brass and steel versions...either version is acceptable to me for my use.
Prefer complete assembly with bracket and clamp.
Hoping someone out there has one of these in their spares box and can help me out.
Best Regards,
Cliff Ward
Cary, North Carolina
Cliff Ward
clifforddward is offline   Reply With Quote
Old 01-26-2024, 03:10 PM   #2
clifforddward
Default FOUND!: Looking for A-3520F Steering Column Support Bracket
Found one!....thanks folks!....
longer steering column support bracket as used on 190-A Victoria, A400, and Delux Phaeton. I think it was also used on the Model A bus. Part number part is A-3520F It is the "F" that designates this longer version.
Cliff Ward
