01-19-2012, 02:37 PM | #1 |
Oil Pump Screen
How do get to the screen on the oil pump for cleaning. I removed the one screw on the top cover but the cover wont budge. Am I missing something?
01-19-2012, 06:12 PM | #2 |
Re: Oil Pump Screen
There are 2 different pumps. One does not have any screws on the cover and are not re-buildable. The other should have 2 screws on the cover and are removable. You can also remove the bottom plate and pull the screen off there. If I were cleaning the pump, I would remove both, the cover and the bottom plate and clean inside the housing.
01-19-2012, 09:31 PM | #3 |
Re: Oil Pump Screen
thanks for your sugestion I found the second screw and removed the screen. I am sure glad I did it was all gummed up. thanks again
01-19-2012, 10:03 PM | #4 |
Re: Oil Pump Screen
