05-26-2010, 11:17 AM | #21 |
Re: Difference between a 59ab and stock 46-48 Flathead
How does somebody tell the year the block was actually cast ?
05-26-2010, 05:20 PM | #22 |
Thanks Bruce.
08-11-2015, 11:28 AM | #23 |
Carbon dating.
Alan |
08-11-2015, 11:57 AM | #24 | |
http://automotivemileposts.com/ford/...rtnumbers.html http://flatheaddrag.com/birthday.html http://flatheaddrag.com/links.html http://www.telusplanet.net/public/bboogaar/engine.htm http://www.mustangtek.com/FordDecode.html Last edited by Capn John; 08-11-2015 at 12:03 PM. |
11-02-2016, 02:45 PM | #25 |
someone told me (he said, she said) that when ford did the motors over ,like the factory branch that was in boston they had set the crank up for insert bearings instead of the floaters. any truth to that ?
11-02-2016, 03:47 PM | #26 |
59 A, AB, more...The block was a 59A, just meaning its first design purpose was for passenger even though it was used in all vehicles. The B, which appears only on 59 AB heads after some time during 1946, is from the OTHER end of the part number and indicates a design change, namely smaller chamber. The number would have been 59A-6050B |
11-02-2016, 05:01 PM | #27 |
Ford farmed out the overhauls to "authorized" facilities. If they had to change a crankshaft due to crank & rod damage, it may have been easier to install an 8BA crank & rods. There was also the C69A Canadian engine that had insert bearings in the mains & rods from new. I'm sure they used what they had to keep the costs low & profit high so I imagine they would use the floaters on an engine that still had a good rotating assembly. These shops would have had to take care and use appropriate bearings for a crank that had only one oil port per con rod throw. Insert rods would have to go with a crank that had two ports per con rod throw or there would have been a warranty problem for sure and no one likes the problems.
