Old 01-22-2024, 04:15 PM   #1
Woodie1
Woodie1's Avatar
Default puzzled
Our Model A did this last winter & now I find it has done it again. I have maybe 1/2 quart of water on the floor. I can't find any wet spots on the radiator but i am guessing there must be a leak. It doesn't lose coolant at all in the warmer weather. The drip point seems to line up with the front cross member. What do you think?
Woodie1 is offline   Reply With Quote
Old 01-22-2024, 04:45 PM   #2
P.S.
Default Re: puzzled
Check the water pump. When it's cold, and things shrink, could be losing coolant from the shaft. Tightening the packing nut may solve that.
When a water pump leaks, it can run down the front of the block, down the front motor mount area, and looks like it's coming from the radiator.
2024 MAFCA Technical Director
P.S. is offline   Reply With Quote
Old 01-22-2024, 04:47 PM   #3
rotorwrench
rotorwrench's Avatar
Default Re: puzzled
You state "water" in reference to engine coolant. Is is straight water or anti-freeze mix? Water will freeze pretty quick if the temperature gets low enough. The expansion rate will stretch and possibly crack metals. Rubber hose just expands. A lot depends on how hard a freeze event it was.
Old 01-22-2024, 05:30 PM   #4
Big hammer
Default Re: puzzled
I was under my A working on adjusting the steering gear box and drip drip drip, tightened the upper hose clamps no more dripping. Why would a hose just start leaking ? Glad it was in the garage !
get a bigger hammer tap done
Old 01-22-2024, 06:16 PM   #5
Woodie1
Woodie1's Avatar
Default Re: puzzled
It is a coolant mix, not plain water. It wasn't froze on the floor. I didn't see any water in the area of the front main cap bolts. Usually I will see water there if the pump is dripping.
Old 01-22-2024, 06:55 PM   #6
1crosscut
1crosscut's Avatar
Default Re: puzzled
Take some toilet paper and start dabbing around on the engine checking for the paper getting wet. Does a really good job of finding elusive coolant leaks.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 01-22-2024, 07:14 PM   #7
Woodie1
Woodie1's Avatar
Default Re: puzzled
I'll have to try the toilet paper trick.
Old 01-22-2024, 07:22 PM   #8
GPierce
GPierce's Avatar
Default Re: puzzled
I have had cooling systems leak a small amount water when cooling down and then quit.
Usually tightening the hose connections cures it.
GPierce is online now   Reply With Quote
Old 01-22-2024, 07:40 PM   #9
Gary WA
Gary WA's Avatar
Default Re: puzzled
Upper hose connection at radiator under neath by the neck loose clamp!
www.whidbeymodelaclub.com
Old 01-22-2024, 08:46 PM   #10
Doug Linden
Doug Linden's Avatar
Default Re: puzzled
It wouldn't hurt to tighten all the hose clamps as this could be the source of the leak(s)
Doug Linden is offline   Reply With Quote
Old 01-22-2024, 09:34 PM   #11
Woodie1
Woodie1's Avatar
Default Re: puzzled
Good ideas on the clamps. I shouldn't assume they are tight.
Old 01-22-2024, 10:43 PM   #12
Gary WA
Gary WA's Avatar
Default Re: puzzled
or located on hose properly!!
Old 01-23-2024, 04:43 PM   #13
rotorwrench
Default Re: puzzled
Water is the only thing that expands in freezing temperatures. Everything else contracts. The rubber hose likely doesn't contract as much as the steel or cast iron hose attachments or the brass radiator hose couplings. Hose clamps may not contract all that much due to the way they are formed.
Old 01-24-2024, 12:49 PM   #14
1928Mik
1928Mik's Avatar
Default Re: puzzled
My car has always been stored in a basement heated garage until my Mom passed away last year. We liquidated the house and I moved it into a semi-heated warehouse at my business. When the temps got colder I noticed coolant (mix) all over the floor. All the hose connections were leaking as well as the packing nut on the water pump. The temp difference caused everything to loosen up. Tightened it all and no more leaks.....
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 01-24-2024, 04:28 PM   #15
Y-Blockhead
Y-Blockhead's Avatar
Default Re: puzzled
Whenever I have an elusive leak, I turn to "modern technology".
Add a bottle of UV dye to your radiation, run engine, wait 'till it is dark out. Use a Blacklight to trace the leak(s)
https://www.amazon.com/Interdynamics...s%2C219&sr=8-5
