Old 09-09-2012, 03:53 PM   #21
Bob C
Default Re: 30 Starting... No fuel to cylinders, just carb
You should have a nice blue spark and it should jump at least 1/4".
Bob
Old 09-09-2012, 04:29 PM   #22
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
With just the rotor oon the dist, hold coil wire barely above rotor metal spring, long crank to see if spark is jumping "THROUGH" THE ROTOR & grounding out to the dist shaft. A very SLIGHT, thin spark might be seen, but shouldn't see a strong CRACKLE like spark. Look inside rotor bore, if it's been arcing, it usually leaves a rainbow lookin' discoloration in the bottom of that hole. Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 09-09-2012, 07:13 PM   #23
1931 flamingo
1931 flamingo's Avatar
Change the coil and condenser, probably condenser first. JMO
Paul in CT
Old 09-09-2012, 08:28 PM   #24
bogdonj
bogdonj's Avatar
Change the condenser and make sure the inside screw that hold the condenser is there and tight... I had the same symptoms as you and for days exhausted myself trying to trace the problem down and just happened to look and the dist and seen the set screw for the condenser missing...replaced it and it started on its first crank
_________________________________________
1931 Ford Model A Tudor
1930 Ford Model A Deluxe Roadster
1930 Ford Original Rolling Chassis- Restoring
bogdonj is offline   Reply With Quote
Old 09-09-2012, 09:49 PM   #25
Tulsa
Where is The set screw on the condenser? On the bottom?
Tulsa is offline   Reply With Quote
Old 09-09-2012, 10:14 PM   #26
bogdonj
bogdonj's Avatar
Look at the dist and find the hole on it take a light and u will see a screw in there (drivers side)
Old 09-09-2012, 10:32 PM   #27
Tulsa
So driver side there is an access hole for the set screw on side of distributor?
Old 09-09-2012, 10:41 PM   #28
Tulsa
I see a spot on pass side. No screw. Threaded for small screw. Is that it? On pass side of dist.
Only hole I see on driver side is a thru hole on forward side. Then one on rear side that a wire goes into.
Old 09-09-2012, 10:41 PM   #29
bogdonj
bogdonj's Avatar
Correct it grounds the condenser I believe..may not be your problem but check to make sure it's there or try changing out the condenser....it's easy to do and doesn't take long
Old 09-09-2012, 10:47 PM   #30
Tulsa
Were you Still getting spark before you found that problem?
Old 09-09-2012, 10:47 PM   #31
bogdonj
bogdonj's Avatar
Pic of the dis.. does yours have this?
Old 09-09-2012, 10:51 PM   #32
Tulsa
No!!! I'm getting excited now! Where can I get one of those parts? Just have the hole
So I can still get spark but this part does what?
Old 09-09-2012, 10:51 PM   #33
bogdonj
bogdonj's Avatar
Yes.. I was getting spark.. it was the most frustrating thing ever. This is a video of me trying to start it... felt like it wasn't getting gas but it was.
https://www.youtube.com/watch?v=gddWy...6&feature=plcp
Finally got it running but used alot of throttle to try and keep it going... right after this I noticed the screw missing on the inside of the dis that hold the condenser...changed it out and started right up. again, this might NOT be your problem but its good to check... it took me a week to figure it out.. patients is the best.
Old 09-09-2012, 10:56 PM   #34
Tulsa
What's the part called? Where did you get it?
Old 09-09-2012, 10:59 PM   #35
bogdonj
bogdonj's Avatar
http://macsautoparts.com/model-a-for...0R3CHL1065715/
remember to buy the screw also.... MAC's is what most people use... I'm in Canada so I have suppliers that I buy from here also.
Do you have a pictures of your dis? be interesting to see what it looks like
Old 09-09-2012, 11:06 PM   #36
Tulsa
Yeah it doesn't have the condenser at all. I found another dist in my bin of extra parts. I will toss it in there tomorrow and try it. I will snap some pics then. Thanks for the help!
Old 09-09-2012, 11:12 PM   #37
bogdonj
bogdonj's Avatar
No worries, just remember the old condenser that you have may be garbage also..then again some would say the new ones don't last long either. keep us updated.. interested to see what happens tomorrow. This is definitely your problem if you don't have one currently in the dist.
Old 09-09-2012, 11:22 PM   #38
Tulsa
Sweet. We will try this one and if nothing order a new one asap!
Old 09-09-2012, 11:34 PM   #39
redmodelt
redmodelt's Avatar
If you have a NAPA store they may have one in stock or get it the next day or so.
Old 09-10-2012, 03:22 AM   #40
Tom Wesenberg
Tom Wesenberg's Avatar
The condenser keeps the points from arcing and burning up quickly. It also greatly intensifies the spark.
Sometimes owners have removed the condenser from the distributor and mounted one up on the coil. Do you have one on the coil?
