Old 01-23-2022, 09:35 PM   #1
woofa.express
woofa.express's Avatar
Default Sparkplugs. I was rewarded following exhaustive search.
Buying where the price is low has become more important to me now I don’t have an income except 0.4% bank interest ( which equates to approximately nil). Getting money from my treasurer, otherwise known as my wife is not dissimilar to extracting teeth from a dingo (wild dog).
I have spent 2 days looking for sparkplugs for my Model A. When I did eventually find some they were $62 from repco but were on special for $50. I couldn’t find a suitable alternate. But after more searching I eventually did. Advertised on a John Deere website in America for 6usd. I called a local John Deere here in Australia, and yes they had them. 11aud. What a relief.
I am pleased to pass that on to you readers for it might just help you as indeed you have helped me on this as well as other matters in the past. It is also worth a mention, years ago I operated an Airtractor powered with a Pratt 1340 (cc) engine and the electrical components were also available from John Deere. The designer / builder of that aeroplane knew they would be operated in agricultural areas, the same sort of places one would find John Deere spare parts.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 01-23-2022, 10:07 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Sparkplugs. I was rewarded following exhaustive search.
It pays to shop around!! Well Done!Thanks to your wife!!
www.whidbeymodelaclub.com
Old 01-23-2022, 11:36 PM   #3
woofa.express
__________________________________________________ __________________________
My aviation friend says that Airtractor with the Pratt engine would perform better if it had a 1340 cubic inch engine not a 1340 cc (cubic centimetre) engine. Yes he is quite correct.
I know many things,
Old 01-24-2022, 02:58 AM   #4
dave in australia
What was the part number for the John Deere plugs?
dave in australia is offline   Reply With Quote
Old 01-24-2022, 01:17 PM   #5
woofa.express
Hi Dave. John Deere AC600R. Apparently marketed for lawn mowers or ride on mowers. I also found a site of cross references. I did endeavour to copy link but site wouldn't permit. There was many comparable but I wasn't able to find any when I was searching yesterday. There is perhaps one unknown and that is the "M" on the plug. This below is specs from website.
CORE NOSE PROJECTION
RETRACTED No Projection
H .020"-.030"
Y .060"-.090"
M .100"-.140"
L .180"-.220"
E .240"-.300"
cheers, gary
I know many things,
Old 01-24-2022, 01:43 PM   #6
Mike Peters
Mike Peters's Avatar
https://www.jdfanatics.com/threads/s...nce-chart.144/
Here's a cross reference chart showing the AC600R JD part#. Third one from the bottom on the right under JD part #'s. Shows it crosses over to a Champion W18, which is an 18mm plug. Fits many antique 2 cylinder JD tractors, but will also work great in a Model A. Good catch, Gary.
Mike Peters is offline   Reply With Quote
Old 01-24-2022, 02:39 PM   #7
Benson
Benson's Avatar
gary,
1940's Model L Gravely walk behind garden tractors use Autolite 3076 which works for highway use in Model A.
https://www.amazon.com/Autolite-3076..._t3_B01B8NHTUQ
Autolite 3077 has a rather extended tip that extends into combustion chamber but does not hit anything with a Police Head. Has Model A threads.
Heat range is warmer than 3076. I have used them around town a few years ago.
You might find cross reference tables which will lead you other plugs that will work from Caterpiller and other heavy machines.
https://www.sparkplug-crossreference.../AUTOLITE/3076
3076 looks similar to W18
3077
Old 01-24-2022, 03:14 PM   #8
Benson
Benson's Avatar
This cross reference looks good.
Corrected URL:
https://www.autolite.com/docs/defaul...ref_0311_0.pdf
I hit control F on webpage and typed 3076 in search box. It crosses 49 different manufacture's plugs.
I will bet that you could cross W18 and others to find many other machines that use similar plugs.
Also in recent years Champion changed their numbering system.
Example W18 is called 518
Old 01-25-2022, 03:01 PM   #9
woofa.express
Thankyou to Benson and Mike Peters
I know many things,
Old 01-25-2022, 03:54 PM   #10
ronn
ah the infamous dingo............................!
Old 01-25-2022, 09:20 PM   #11
woofa.express
Well too bad about the dingo. What about the bites on my hands and fingers?
I know many things,
Old 01-26-2022, 02:02 AM   #12
40 Deluxe
Are dingos any good at controlling the rabbit overpopulation?
Old 01-26-2022, 03:03 AM   #13
woofa.express
yes, I guess so Allan but not as good as the virus calivirus or mixamotosis. Without the viruses we would be overrun by rabbits that even dingos could keep under control. They were handy, the rabbits that is, in the depression. but today there are few who can skin a rabbit or pluck a duck. Guess they could learn fast though. Cheers, gary
I know many things,
Old 01-26-2022, 06:53 AM   #14
updraught
updraught's Avatar
https://www.nrdc.org/onearth/dingo-ate-my-bunny
https://www.amusingplanet.com/2016/0...australia.html
We don't like having chocolate bunnies at Easter as they are a pest. Chocolate Bilbies are far more politically correct.
updraught is offline   Reply With Quote
Old 01-26-2022, 01:36 PM   #15
woofa.express
They were a couple of good links updraft. You mentioned bilbies. A delightful and harmless little fellow in small populations because both dingos and cats, (domesticated and wild cats) clean them out.
Pictures. 1. A rabbit kill. I can't determine the make of this truck, maybe a reader can, and 2 the Bilby. The animal itself and the chocolate one updraft says should substitute the easter bunny.
I know many things,
Old 01-28-2022, 12:40 PM   #16
Jim Brierley
Woofa, You have a way in getting a lot of responses to your posts! Fortunately I speak Aussie fairly well, so usually understand what you are saying. It's been a bit cool here in SoCal, but tolerable. Stay cool!
Old 01-28-2022, 04:23 PM   #17
woofa.express
Hi Jim my friend. You're a ripper. Stay that way, don't ever change.
Wish it would cool down here. gary
I know many things,
