Old 01-31-2019, 08:18 PM   #1
Low1954
Default 1939-1941 Ford front and rear brake baking plates
I need help identifying the 1939-1940 Ford brake baking plates. I'm in search of some and want to know what I'm looking for. Also would like to know what the front hubs and spindles should look like. Pictures would be awesome.
Thanks Jeremy
Low1954 is offline   Reply With Quote
Old 01-31-2019, 10:43 PM   #2
Gary in La.
Gary in La.'s Avatar
Default Re: 1939-1941 Ford front and rear brake baking plates
This is a set off from a 1941; Same from 1939 to 1941.
Gary in La. is offline   Reply With Quote
Old 01-31-2019, 11:14 PM   #3
Charlie Stephens
Jeremy,
Any reason you are not going to the '42-'48 backing plates? Most people consider the later backing plates easier to adjust.
You should put your general location in your profile, you can never tell when it will pay off.
Charlie Stephens
Old 02-01-2019, 09:58 AM   #4
rich b
rich b's Avatar
'37-'41 spindles look like this. Drag link eye was tapered from the top down in '41.
Old 02-01-2019, 11:20 AM   #5
tubman
tubman's Avatar
I always preferred the early hydraulic brakes because of the greater "adjustability" provided by the moveable bottom anchors. Granted, they were more difficult to get adjusted properly, but once you had them right, I think they worked better.
Old 02-01-2019, 11:37 AM   #6
19Fordy
19Fordy's Avatar
Here's some photos of 40 front parts that may help. This car has dropped steering arms but the taper is same as OEM.
