Old 03-11-2018, 08:32 AM   #1
Bob from Northport
Bob from Northport's Avatar
Default Windshield glass installation
Anyone have any tried and true methods for installing the glass in the windshield frame. Doing a 1930 Sport Coupe. Brattons mentions using oil on the glass tape.
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 03-11-2018, 08:36 AM   #2
Afordman31
Afordman31's Avatar
Default Re: Windshield glass installation
That is the way my brother and I did his. We cut off the excess with a scalpel, We put a metal rule tight to the frame and cut along that to get a clean cut without bothering the paint!
Afordman31 is offline   Reply With Quote
Old 03-11-2018, 10:23 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
The setting tape comes in a couple thickness, so be sure to get the correct one.
I had to reorder to get the thinner tape.
I used bar clamps and wood blocks to pull the glass into position.
Old 03-11-2018, 11:33 AM   #4
BillCNC
BillCNC's Avatar
I need to redo my rubber seals in my windshield, does anyone know where I can get an exploded view of the windshield for a 31 Tudor?
Regards
Bill
BillCNC is offline   Reply With Quote
Old 03-11-2018, 02:44 PM   #5
wrndln
Not to hijack the string, but I need to install the glass on my 29 phaeton windshield frame. I have the frame nicely painted and I don't want to damage the paint on the frame. The top is straight, but the bottom is curved. I can use rags or cloth to protect the top. I used pipe clamps when installing the glass in the 28 coupe windshield frame and it worked fine. However, an open car frame only has a tube on the bottom of the frame and it more fragile. I can't think of anything to use to protect the curved bottom of the frame from damage and sliding from the pipe clamps.
Rusty Nelson
Old 03-11-2018, 06:08 PM   #6
Ron in Quincy
Ron in Quincy's Avatar
Some of the tape that dealers sell is too thick.
When I put the glass in my 30 Coupe I went to a glass shop and found he had 3 different thickness of tape, he gave me a thinner tape than what the dealer had sent. The glass went right in with no problem.
Ron
Ron in Quincy is offline   Reply With Quote
Old 03-12-2018, 07:33 AM   #7
chap52
chap52's Avatar
I use dish soap and water mixture instead of oil. easier to clean up after. Chap
chap52 is offline   Reply With Quote
Old 03-12-2018, 01:20 PM   #8
Cape Codder
Cape Codder's Avatar
I HAD my done by a glass shop a year ago. THEY BROKE two pieces of glass before getting the third one in. Sure happy I took it to them because the first two were on their dime.
Cape Codder is offline   Reply With Quote
Old 03-12-2018, 07:08 PM   #9
desotoguy
Having a freshly painted ws frame, and needing to install the glass without damaging the paint, I came up with this solution.
Two pieces of 2x4"x 24", slot 1" deep x 1/4" + setting tape thickness wide in the center of each.
Stretched the set tape completely around the glass, joint at the center top.
Set the glass in the slots, top down.
Water with dish soap of the tape.
Lower 3 sided frame down onto glass, push until completely set. I was able to set without excessive force, ie hammer.
Turn frame with glass right side up and install the top metal and screws.
Trim away excess set tape.
This worked for me, no paint chips or marring.
desotoguy is offline   Reply With Quote
Old 03-12-2018, 08:31 PM   #10
Tinbasher
Tinbasher's Avatar
Hand Cleaner with Lanolin in it works really well to lub. the glass pack. I like to paint the frame first around the inner edge and then put it together. Then mask up the glass and paint the rest of the frame. That way I can use a wood block and a plastic hammer to put the frame together. Closed or open car.
Tinbasher is offline   Reply With Quote
Old 03-16-2018, 02:23 PM   #11
Dave in MN
Dave in MN's Avatar
Rusty Nelson
Rusty,
Post #9 method worked for me also. I used Dawn soap at 100% (no water). I did not need to use any tools to get it to come together.
18 years and the glass is still good in the frame.
Good Day!
Dave in MN is offline   Reply With Quote
Old 03-16-2018, 03:04 PM   #12
wrndln
Thanks for the post Dave.
Rusty Nelson
Old 03-16-2018, 06:49 PM   #13
daren007
If you have to force the glass you are using tape of the wrong thickness. The glass should slid in without much effort. Coat the tape with oil. After setting awhile the tape will swell. This applies to the lift channel as well.
daren007 is offline   Reply With Quote
Old 02-25-2019, 07:11 PM   #14
moasew
Tom:
Can you send me a drawing or photo of how the corners should look on the windshield glass setting tape? I tried using the rubber tape but not much luck. I have ordered the cork/rubber combo to use instead but still need to mitre the corners.
moasew is offline   Reply With Quote
Old 02-25-2019, 08:30 PM   #15
midgetracer
midgetracer's Avatar
The new rubber tape that wants you to use oil to make it swell did not work for me. I had a mess of black gunk all over. I am not an expert, but the cork /rubber tape made a nice install. all I had to do was trim the excess using a thin metal ruler.
midgetracer is offline   Reply With Quote
Old 02-26-2019, 03:58 AM   #16
Tom Wesenberg
I taped the edges of the setting tape to the glass, then fold the setting tape around the lower corners of the glass and use a razor to cut the 45* corners, so the horizontal and vertical parts of the setting tape fit nicely together. I used a 6" piece of wood and hammer to tap the glass into the frame. As I recall some Vaseline helped, then use a razor to trim the setting tape once the top of the frame is screwed down. Slow and easy so you don't cut the glass.
Old 02-26-2019, 07:43 AM   #17
old31
45* corners?
Does anyone have a picture of how the corners should look?
Old 02-27-2019, 11:13 AM   #18
Tom Wesenberg
Originally Posted by old31 View Post
45* corners?
Due to all the snow and cold weather, I can't get to my cars to take pictures.
I'd think a Google search would turn up something.
Old 02-27-2019, 08:40 PM   #19
larrys40
Tom,
I thought we had a pretty good time installing the windshield at Brent’s last year.
It went in well. We were a good team at it.
The video link is out there somewhere
Larry
larrys40 is offline   Reply With Quote
Old 03-03-2019, 02:47 PM   #20
moasew
I've googled and googled but no luck finding the detail on the corners. Just a general installation video.
