Old 04-08-2021, 07:04 PM   #1
MSmelcer40
MSmelcer40's Avatar
Default New 1940 Truck project ,front clip removal
What is the benefits of removing the whole front clip vs removing one fender at a time and then grill ect? It seems easier to do the hammer and dent removal completely dis assembled.Im totally new and excited to start.Thanks
MSmelcer40 is offline   Reply With Quote
Old 04-08-2021, 07:24 PM   #2
Kube
Kube's Avatar
Default Re: New 1940 Truck project ,front clip removal
As the grille is pot metal, it can easily break when placed under stress. that being the case, I'd remove the grille as an assembly first. Then, a fender and then the other fender.
Is this a half ton?
Old 04-08-2021, 07:30 PM   #3
MSmelcer40
MSmelcer40's Avatar
Yes its a 1/2 ton. I have to agree with you..I just see fellas carrying the whole front clip around the shop
Old 04-08-2021, 07:43 PM   #4
Kube
Kube's Avatar
Well, it sounds as if you are planning on bumping and filing. Thus, you will need to disassemble the front clip in to as many pieces as there are. Why take a chance at breaking and / or twisting anything?
Lots of folks do lots of things...
Old 04-09-2021, 05:46 AM   #5
MikeinMass
Take lots of photos and notes .zip lock baggy the bolts and label. Ask me why . BABY that grill
Sent from my SM-A215U using Tapatalk
MikeinMass is offline   Reply With Quote
Old 04-09-2021, 06:10 AM   #6
MSmelcer40
MSmelcer40's Avatar
I'll certainly take that advice seriously. My 40 is almost completely rust free but there's plenty of dents to keep me busy.thanks so much for the info
Old 08-22-2021, 11:59 AM   #7
Shortbed12
Someone took the front clip apart on my 40
And half assed put it back together so I have to start from scratch
No pictures for me
Shortbed12 is offline   Reply With Quote
Old 08-22-2021, 07:25 PM   #8
V8COOPMAN
V8COOPMAN's Avatar
No pictures for me
Shortbed .....In case you missed it, I posted the pics you need in another thread......CLICK THE LINK BELOW! Hope this helps!! DD
https://www.fordbarn.com/forum/showp...7&postcount=27
Click Links Below __
T5 W/TORQUE TUBE
Old 08-23-2021, 09:35 AM   #9
TJ
TJ's Avatar
Unless it is necessary, I would leave the hood in place for alignment purposes.
