08-01-2020, 08:48 PM | #41 |
Re: Oversized Brake Drums
Bite the bullet and have your drums relined by J&G. And, while your at it have the shoes relined with semi metallic composite and arched for each respective wheel. I had this done by these folks for my 37 LaSalle. This is not a garage shop. They know what they're doing. I can now drive at highway speeds and feel under control.
08-02-2020, 07:32 AM | #42 |
I just replaced all the brake lines on my 49 Ford. Two of the old lines had compression fittings.
08-02-2020, 08:17 AM | #43 | |
Good for them and good for you
08-02-2020, 11:14 AM | #44 |
Flathead Ted has the solution.
The small percentage of 1935 Ford owners interested in Points Judging will seek out original drums. It doesn’t make sense to pursue original drums for a driver. I can spend over $400 per drum to have them relined or buy a new made in USA 40-48 drums for $135.
Tim Downtown, Ca |
08-02-2020, 02:50 PM | #45 |
We had remachined F100 drums on our 32 , it passed all the brake tests and got complied . I was never happy with the brakes as on a hard stop the pedal would go away some . Took a long time of investigating to find the drums were over machined past.060 and on hard braking they were growing . New drums and linings solved any issues.
Do not over machine your drums |
08-02-2020, 08:28 PM | #46 | |
08-03-2020, 11:15 AM | #47 |
FWIW:
I just heard from Reddaway, they have been in business since 1890s. The modern woven lining that they sell; RNAW woven lining has Kevlar fibers and he states that it won’t accelerate drum wear. http://www.redcoproducts.com/wbl.htm
Tim Downtown, Ca |
