Old 01-09-2017, 01:28 PM   #21
Chris
Chris's Avatar
Default Re: Installing windshield on 1941-1948 Ford- sealant?
Thanks everyone, that gives me some great info on what I should do. I think I will try installing the trim afterwards, beings that is the way I believe it was made to be done. And I will try Napa's 4121 sealer after it is installed and dry.
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 01-11-2017, 04:49 PM   #22
fordor41
fordor41's Avatar
Originally Posted by flathead48 View Post
I have installed two windshields in 48 Fords and I put the stainless in after the installation. I have never tried putting the SS in first but I would be afraid of damaging it. A old parts catalog from Dennis Carpenter shows the steps and he shows SS last and no sealant just liquid soap so it will go in easier. You do need a second person to hold it in from inside the vehicle while you pull the string on the outside. Hope this helps.
I installed mine with D.C. seal. Instructions said" No sealant necessary". Leaked at the corners so I called them and they said "Did you use sealant on the seal"???
fordor41 is offline   Reply With Quote
Old 01-12-2017, 10:55 AM   #23
TJ
TJ's Avatar
Use dish soap to install the stainless trim. It will wash off and not harm the rubber. I would be reluctant to use grease as stated in a previous post. Sometimes grease and some types of rubber do not mix well.
