Old 12-13-2018, 12:35 PM   #1
ford35lh
Default Lug wrench/crank handle ID
The top one is 3/4 diameter with fatter ends which has the 13/16 hex
and 11/16 square holes on the ends.
The second one down has a 3/4 hex hole but everything else is the
same as the third down
The third one is ,I believe, B 17036-C, as the crank socket is 2 7/8 long.
The bottom wrench in the photo is,I believe, 68-17035; short lived.
Any help to identify would be appreciated.
ford35lh is offline   Reply With Quote
Old 12-14-2018, 04:15 PM   #2
JM 35 Sedan
JM 35 Sedan's Avatar
Default Re: Lug wrench/crank handle ID
You may have thought pictures posted with your message, but they didn't, or at least I didn't see them. If you need some help posting pics, just let us know. Someone can post these for you.
John
Old 12-15-2018, 12:10 AM   #3
ford35lh
Thanks JM.
