11-05-2012, 07:07 PM | #1 |
How do I install Radiator Splash Shield?
Do I have to remove radiator shell to install Splash Shield on 1931 Sedan?
11-05-2012, 07:44 PM | #2 |
Re: How do I install Radiator Splash Shield?
If you are talking about the baffle in the top radiator tank: you will have to remove the shell, and remove the radiator. Take the radiator to a radiator repair shop. They will remove the top tank and install the baffle in the top tank, and then install the top tank.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
11-05-2012, 08:35 PM | #3 |
If you mean the splash shield below rad,just remove the 2 horizontal screws on each side of apron & 2 vertical screws on each side & apron can be removed.
11-05-2012, 09:52 PM | #4 | |
never gave it a thought he was talking about the "splash apron" !!!
11-06-2012, 01:15 PM | #5 |
I guess I mean "Splash Apron".
11-06-2012, 06:54 PM | #6 |
http://www.abarnyard.com/ |
