Old 08-05-2012, 10:25 AM   #1
cradlescyth
cradlescyth's Avatar
Default Need Model
I have the # A3344043 This is motor # built in May of 1930
The chassi # is unreadable and all I have is chassi, Is there any way of finding which body went with number.
Thanks for help
cradlescyth is offline   Reply With Quote
Old 08-05-2012, 11:08 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Need Model
you can narrow the choices somewhat by the leaves in the rear spring possibly
Old 08-05-2012, 11:34 AM   #3
juke joint johnny
juke joint johnny's Avatar
If it still has the rear bumper brackets : the short vertical brackets that attach to the body are different lenths for some body styles ,might give you a clue
John Cochran
juke joint johnny is offline   Reply With Quote
Old 08-05-2012, 01:32 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
The frames assembled at the Twin Cities plant had codes on the right rear of the rear crossmember. My 2-23-29 Tudor has T0 for Tudor 10 leaf. My 9-27-28 Phaeton has P8 for Phaeton 8 leaf.
Old 08-05-2012, 03:21 PM   #5
329s
Other than the above clues...NO...However, if you are very lucky enough to find the original Bill of Sale (factory or dealer) with that number on it...then you will know for sure just what body style went on the chassis.
Pluck
329s is offline   Reply With Quote
