05-03-2021, 09:49 PM | #1 |
41 helmet clearances
Hello all, I am new to the flathead engines.
I have a 41 ford with the stock helmet distributor, I had the points set by a guy that has the fixture, and installed new plug wires and repro inner caps. my question is, what is the cap to rotor gap, I've seen everything from .010 to .025 so not sure, also can this be done on the engine or on the bench, im looking down through the coil hole, not sure how to gap the bottom contacts any advise recommendations would be greatly appreciated! Thanks Guys! Last edited by mick1; 05-04-2021 at 03:10 PM. |
05-03-2021, 11:34 PM | #2 |
Re: 41 helmet clearances
Just about anything to be done on a helmet distributor should be done on the bench then
final adjustments on a machine like a Sun or Allen. Seeing the rotor gaps on the lower contacts would be a real challenge on the car, if possible at all. Best done with the opposite inner cap off. |
05-04-2021, 12:20 AM | #3 |
If you have good strong spark its not so critical 1 32/ to 1/16 ,we have turned the cap of in the past to go deeper .
05-04-2021, 05:59 AM | #4 |
