12-30-2014, 11:34 PM | #21 |
Re: Battery Location
I've run a 12 volt batterys in the normal location on model A's for many years and never had a problem. Some get confused about positive ground and charge the battery up backwards, then when the battery is connected correctly it will blow up.
12-30-2014, 11:42 PM | #22 |
The drivers side floor was the practical location for the battery. If the battery was installed on the passengers side under the floor boards it would be right over the muffler. If you've ever ridden on the passenger side you will know that the floorboards get hot. It would be DANE-JUS for the battery to be mounted over the very hot muffler .
11-27-2023, 04:18 AM | #23 |
Any input on the idea of mounting the battery in a box on the driver's side running board? I would like to add decent carpet and better sound insulation to the floor and having to remove it to get at the battery is not great. Perhaps a metal box sprayed body color and running the cables through the running board and along the frame to the front?
11-27-2023, 09:50 AM | #24 |
Owning a model A is like being married to a woman. Any attempt at changing her nature will lead only to tears and disappointment.
11-27-2023, 10:25 AM | #25 | |
Snyder's sell a kit or fab your own https://www.snydersantiqueauto.com/p...7804&cat=41699 Last edited by Y-Blockhead; 11-27-2023 at 10:35 AM. |
11-27-2023, 11:16 AM | #26 | |
Many confuse the Model T pickup bed with the Model A, especially when the bed is separated from the car. But the Model T differed in making accommodation for a battery below the bed floor boards. A metal plate similar to the plate used in the Model A foot board allowed access to the battery from the top for servicing - but not replacement. A short video (4 seconds) of a 1927 Model T battery replacement. Interesting in that the bracket apparently "swivels" to allow the battery to be removed. https://www.youtube.com/watch?v=8tYRzqACiwY Joe K
Shudda kept the horse. |
