08-14-2020, 11:30 AM | #1 |
Master cylinder push rod boot two options ?.
First one is from Drake and Carpenter
Second one from C&G and others. I assume the 2nd one is correct for my '41. |
08-14-2020, 11:36 AM | #2 |
Re: Master cylinder push rod boot two options ?.
The second one appears to be correct. However, from my experience the hole that (should) seal the rod is too large in diameter. You may want to check on that prior to ordering.
08-14-2020, 05:12 PM | #3 |
