Old 01-30-2011, 11:32 AM   #1
jim1932
jim1932's Avatar
Default 32 Tudor parts?
The cover was in a box in the Model B when I got it. Anyone know where it goes? Also, can you ID the horn? there isn't a plate on it that I can see unless he painted over it.
Thanks!
jim1932 is offline   Reply With Quote
Old 01-30-2011, 11:58 AM   #2
Kerk
Default Re: 32 Tudor parts?
Jim, The plate is for the clutch & brake pedal area and goes around the steering col. The horn is correct and is a Klaxon with the Boat tail back & an an expensive part if you are looking for one. I kept the Original one from my 1st car A Deluxe 32 Tudor.
Kerk is offline   Reply With Quote
Old 01-30-2011, 02:46 PM   #3
Steve/IL
Steve/IL's Avatar
Not sure about Klaxon. All the 32 boat tail horns that I have seen have a Sparton tag on the top of the rear cover. Could be that Henry had more than one horn supplier?
I've got the old car disease. Thankfully there's no cure!
Steve/IL is offline   Reply With Quote
Old 01-30-2011, 02:54 PM   #4
Pat/Ohio
Pat/Ohio's Avatar
As Kerk has indicated the floor plate goes on the interior side around the pedals and steering column. There is another steel plate that attaches to the engine side with a rubber foam insulation piece sandwiched in between. These pieces are becoming hard to locate, so hang on to them. If I were you, I would purchased the '32 Ford Book(s) written by David Rehor. A tremendous guide to restoring your '32 Ford. Has many illustrations that will answer many of your questions. Can be purchased from the Early Ford V-8 Club website www.efv8.org or Early Ford V-8 Foundation website at: www.fordv8foundation.org
Good luck, Pat
Pat/Ohio is offline   Reply With Quote
Old 01-30-2011, 03:52 PM   #5
jim1932
jim1932's Avatar
Thanks. I have the book but did not see the plate in there. I was able to identify the two engine covers. I looked for the sparton plates on the horn and didn't see one.
Old 01-30-2011, 08:17 PM   #6
Pat/Ohio
Pat/Ohio's Avatar
Jim, The Sparton tag should be on top of the boattail housing or on flange where the two halves connect. "Sparton" is usually embossed also on the flange area...might look for that. You mentioned that you have the book....Are you speaking of David Rehor's first book (blue), or the new 2-volume book(s). These plates are listed in the new book. If you don't have his newest "creation"...you'll need to get your hands on it. Pat
Old 01-30-2011, 09:08 PM   #7
jim1932
jim1932's Avatar
Pat, I have the two volume one. The horn does not have a tag on it. It has been painted at some point and I am wondering if it had the flange tag but was lost. Are the flange plates attached? or are the held on by the bolts that hold the flange together? I did not see anything stamped in it, but I was looking on the top, not on the butt end.
Old 01-30-2011, 10:06 PM   #8
jerseyboy
jerseyboy's Avatar
Jim,
If you need the outer pedal plate, Renners Corner sells them.
She just don't have the appetite
For gas somehow,
And Dad, I got four carburetors
Hooked up on it now.
I tried to hook another
To see if I'd do a little good,
But ain't no place to put it
'Less I perforate the hood.
Wanted, lower side sections of 32 radiator cowl.
jerseyboy is offline   Reply With Quote
Old 01-30-2011, 10:44 PM   #9
qzjrd5
qzjrd5's Avatar
Your horn appears to be the same model as mine, although I am missing the back cover for mine. No markings or tags on mine either (that I can find). My car was built at the Rouge plant sometime around June 1932. (Note this was not my wiring job! This is an old pic and how I bought the car approx 1 year ago.)
Here's a more recent pic - slightly less dingie!
If it aint done twice, it aint done right!
qzjrd5 is offline   Reply With Quote
Old 01-31-2011, 06:44 AM   #10
jim1932
jim1932's Avatar
I will have to look in my spare box for the other plate (I am afraid to get rid of anything). anyone have a pic of what it looks like? I went through the 1932 book again and still can't find it... of course research isn't my strong suit). qzjrd5, mine has some wiring like that too, just not in red....LOL
Old 01-31-2011, 12:21 PM   #11
jim1932
jim1932's Avatar
Sorry, one more part....these have a slit all the way down like a wire might run through it. about 9" long.
Old 01-31-2011, 12:34 PM   #12
DICK SPADARO
Jim there are three different horns used on 32's two Sparton version like you have, one with a tag curved bolted around the motor body, one with the Sparton tag riveted on the horn cover and a boat tail horn similar to yours but made by GMI. Sparton horns are usually stamped Sparton on the projector body or on the rear peak edge of the horn cover. GMI horns have a small circular GMI mark stamped on the rear peak edge of the horn cover. The later version of the horn is a beep horn which has a round dome shaped motor cover. Yours is either a Sparton or GMI based on the marking that might be pinted over.
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
Old 01-31-2011, 03:12 PM   #13
jim1932
jim1932's Avatar
Can anyone either post a picture of where this cutch brake plate goes, or point me to it in the 1932 ford book? what does the plate that goes on the other side look like?
Old 01-31-2011, 04:39 PM   #14
Pat/Ohio
Pat/Ohio's Avatar
Jim, There is another thread currently on here (32 3W floorboard..I believe). I posted a picture of my newly installed floorboard in 5W Cpe. It partially shows the floorboard plate in the correct position around the steering column and pedals. I am currently on the road and don't have access to my photo files. I will check on photobucket to see if I saved any there. Pat
Old 01-31-2011, 04:42 PM   #15
1931 flamingo
1931 flamingo's Avatar
jim1932: DON"T throw anything away. JMO
Paul in CT
Old 01-31-2011, 04:43 PM   #16
jim1932
jim1932's Avatar
Pat, THANKS! now I see where it goes.... gee my floor boards have a lot more....whats the word??? rot? no more Patina...than yours....LOL
Old 01-31-2011, 04:50 PM   #17
Pat/Ohio
Pat/Ohio's Avatar
Jim, My 5W had a home-made floorboard in it before I gave Roy Nacewics a call. It even had a wooden insulation piece instead of the foam insulation piece. Pat
Old 01-31-2011, 06:29 PM   #18
jerseyboy
jerseyboy's Avatar
Jim,
The plate on the otherside looks like this.
I made this commercial outer plate for my wagon from a pattern. The passenger type is similar, except for the depth of the holes for the column and pedals
You can get both plates and insulation at Renner's Corner.
Keep V-8ing and 4-banging!
For gas somehow,
Old 01-31-2011, 06:40 PM   #19
jerseyboy
jerseyboy's Avatar
Jim,
Here is additional pictures of the plates.
http://www.fordgarage.com/pages/bpedalplates.htm
Picture below shows inner pedal plate on toeboard beneath pedals.
For gas somehow,
Old 01-31-2011, 07:56 PM   #20
Manuel
What water pump is that?
Looks completely sealed.
Manuel in Oz
Manuel is offline   Reply With Quote
Thread Tools
Display Modes
