04-02-2019, 06:58 PM | #1 |
Banjo wheel stainless rod size?
Anybody got a banjo wheel handy and a micrometer that can measure the spokes, mostly the diameter rod that ford used. I need to replace one and I don’t have my wheel with me at the moment. I am thinking 1/8 inch but want to be sure.
Respecting and Resurrecting Ford Model A's. |
04-02-2019, 10:16 PM | #2 |
Re: Banjo wheel stainless rod size?
.125 or 1/8
04-03-2019, 05:18 AM | #3 |
How are you going to replace it, weld, glue etc? How about the little bar that goes across the rods? Just curious, I have one that has one spoke broken.
04-03-2019, 03:14 PM | #4 | |
It is a bar that is on the outer end. I believe the bar that goes across is only attached to the middle bars. I am going to grind off the weld inside the hub that hold them. I have a crack in the rim on that end so I am going to grind the rim down so I can access where it welds to the rim and weld the new one in and restore the rim after.
04-03-2019, 03:36 PM | #5 |
I have a 38/39 banjo wheel here and the spokes measure .144
04-10-2019, 09:03 PM | #6 |
