Go Back   The Ford Barn > The Swap Meet > Wanted > Early V8
Old 12-11-2010, 06:43 PM   #1
toddle321
toddle321's Avatar
Default 1936 Battery Box
City: Chicago
State: IL
Hello,
I'm looking for an original battery box for my '36 passenger car frame. Please let me know if you have one for sale.
Thanks!
Todd
toddle321 is offline   Reply With Quote
Old 12-11-2010, 10:41 PM   #2
Chris B.
Default Re: 1936 Battery Box
It fools you because it isn't a box. It's actually a spar or brace that bolts between the x-member and the outside frame. A flat piece about 16 inches long with a 90 degree angle for the battery to sit on. Mac's Auto Parts has them.
Chris B. is offline   Reply With Quote
Old 12-12-2010, 09:31 AM   #3
toddle321
toddle321's Avatar
Thanks Chris. Do you have a picture of what it looks like installed w/battery?
Old 12-12-2010, 12:49 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
Here are some pics that show the original battery mounting brackets/cross braces (painted black) for a '35 or '36 Ford passenger car. I happen to have an Optima battery mounted in mine that uses a special bolt in mounting box that I fabricated. The Optima and its mounting box can be removed in about 10 minutes if I ever want to go back to a stock group 2LF lead acid battery. Hope these pics help.
John
Old 12-12-2010, 01:25 PM   #5
barnfind08
The bracket in the first picture I make and wholesale to the dealers. I do not make the one in the second picture. There is to y bolts that go into holes in the 2 brackets and the bolt on a holddown which I also make. Let me know if you need or buy from macs or c&g.
barnfind08 is offline   Reply With Quote
Old 12-12-2010, 02:56 PM   #6
toddle321
toddle321's Avatar
Thank you both for the info, seeing it really helped! Barn find, I'll send you a pm to purchase. Thanks again!
