Old 06-28-2017, 07:09 AM   #1
Russ
Russ's Avatar
Default Generator Armature - Long Taper
Does anyone know if there are NEW generator armatures available with the long (7/8") taper? For some reason, the big parts suppliers only sell the short (1/2") taper, which was only used after March (May?) 1930 per the Judging Standards. I'd like to make mine correct for my June '29.
Russ is offline   Reply With Quote
Old 06-28-2017, 09:13 AM   #2
redmodelt
redmodelt's Avatar
Default Re: Generator Armature - Long Taper
A; maybe someone has a good armature, put an ad in the classifieds
B; get yours re wound
C; to be fully correct you also need the correct cover band. ( I know there are differences for the years/months but can not tell you what they are)
Old 06-28-2017, 09:52 AM   #3
1955cj5
1955cj5's Avatar
Bert's has rebuilt units...
https://parts.modelastore.com/show_Product.asp?ID=4032
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 06-29-2017, 08:24 AM   #4
Russ
Russ's Avatar
Thank you for the replies. Looks like, as I suspected, new long-taper armatures are not available.
Old 06-29-2017, 10:06 AM   #5
katy
katy's Avatar
Would it be possible to take a short taper and recut it to a long taper?
Play it again Sam.
Old 06-29-2017, 11:00 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
The long taper was used until March 1930, and it used a ball bearing on the rear. The short taper was used on March 1930 to the end of production, and it used a bushing on the rear, which meant a difference in the rear of the shaft.
There were a few generators with the long taper and rear bushing during the change over period of March 1930. I'll see if I can find my picture of the 3 different armatures.
Old 06-29-2017, 11:22 AM   #7
Russ
Russ's Avatar
I should point out that PV Antique & Classic Ford, which I found through another Fordbarn post, is just now having new long-taper generator armatures manufactured. They will not be available soon enough for my project, so I'm going with a rewound original armature.
Old 06-29-2017, 06:42 PM   #8
Tom Wesenberg
Here's that picture of the 3 different armatures for the long generator.
Notice the top short taper uses a larger thread on the pulley bolt.
Thread Tools
Display Modes
