Old 06-18-2017, 09:55 PM   #1
Steve Plucker
Default 170-A/165-B delimma...
In May of 1929, sent the Ford production department the following letter:
Briggs proposed a change in the 2-W design (60-B and C) as Ford visited the Briggs plant to view the new model (170-A). The letter went on to say: “We (Briggs) also showed them (Ford) a two-window job (170-A) of the same general dimensions as the three-window job (165-B). To enable us to put this job into production (the 170-A) at the same time as the three-window job (165-B) it would mean only a small die expense that we agree to absorb, and in view of the fact that it (165-B) would be longer, wider and better appearing than the two-window job (170-A) that we are going into production on this month, we feel that the job (165-B) shown Mr. Ford would be more desirable to you”. Authentically Speaking by George DeAngles and Edward Francis, Model A News Vol. 14, No. 1, p. 6, 1967.
So here is the question...was the above statement about the 165-B being "longer and wider" than the 170-A correct? OR...Am I missing something?
OR was the 170-A "longer and wider than the 60-B and C body types?
Thanks.
Pluck
Old 06-19-2017, 07:39 AM   #2
jimalabam
jimalabam's Avatar
Default Re: 170-A/165-B delimma...
??? Jim Langley...
jimalabam is offline   Reply With Quote
Old 06-19-2017, 05:26 PM   #3
Roadster62
Roadster62's Avatar
I think the 60C (Steelback) is shorter, I have a nice back half and it is easy to measure things if you need me to. Lets use the door jamb to rear glass as the standard measurement. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 06-19-2017, 08:35 PM   #4
Russ
Russ's Avatar
The 60-C (& A, B) are shorter than the 170-A. The attached photo shows a comparison (note the difference in the shape of the rear quarter). As a side note, the best way to tell a 60-A, B, & C from other cars like the 170-A is to look at the bolt hole pattern on the rear of the car where the spare bracket mounts (not the pattern on the carrier where the spare wheel mounts). The 60-A/B/C has a unique 4-bolt rectangular pattern while the others have a 3-bolt triangle.
Russ is offline   Reply With Quote
Old 06-20-2017, 12:30 AM   #5
Roadster62
Roadster62's Avatar
Russ, Could you post the photos in a normal way, I'd like to see them. Bob
Old 06-20-2017, 08:56 AM   #6
Russ
Russ's Avatar
Reposting 170-A vs. 60-A,B,C file as a .jpg.
Last edited by Russ; 06-20-2017 at 09:25 AM. Reason: Increased resolution of photo.
