Old 05-05-2021, 06:29 PM   #1
Lefthander1930
Lefthander1930's Avatar
Default Push button start Question ??
1 New 12 volt starter
2 new 12 volt solenoid
Cable fron Solenoid to Batt
Cable from batt to ground
Cable fron solenoid to starter
Push button wire (fused) to batt(2 wire button) other wire to S side of solenoid
Engine cranks with key off
On one of the diagrams it show grounding the I side of the solenoid ?? Why If it cranks ?
If I'm good to go I will try & start with gas & work on the fuel line with new pencil
filter & electronic fuel shut off. No more gettin under hood to turn off gas valve.
Lefthander1930 is offline   Reply With Quote
Old 05-05-2021, 07:31 PM   #2
Jacksonlll
Jacksonlll's Avatar
Default Re: Push button start Question ??
That’s probably just a secondary ground if you might need it. Start her up, but have fun doing it.
Old 05-05-2021, 09:54 PM   #3
Leatherback
The "I" on the solenoid is a 12 volt bypass that connects to the ignition coil on the original application of your solenoid. Full 12 volts goes to the coil during starting of the engine. When you let go of the starting switch the coil voltage drops to around 6 volts because of either resistor wire or a ceramic resistor in the ignition circuit. You shouldn't need to connect the "I" post on the solenoid in your application. Good luck with your project. Bob
Leatherback is offline   Reply With Quote
Old 05-06-2021, 11:37 AM   #4
Joop
Joop's Avatar
.This may help
File Type: jpg AEB3750B-4A6D-4D29-B546-B81510656580.jpg (57.7 KB, 52 views)
Joop is offline   Reply With Quote
