Old 03-23-2019, 10:53 AM   #1
flathead34
flathead34's Avatar
Default Emulsion Tube Removal
How do you remove the emulsion tubes from a Stromberg 40, 48, 97 carb. Thanks, Mike
flathead34 is offline   Reply With Quote
Old 03-23-2019, 11:49 AM   #2
Andy
Default Re: Emulsion Tube Removal
I run a small tap down inside and use a piece of welding rod to tap them out. I forget what sized tap. Sorry
Andy is offline   Reply With Quote
Old 03-23-2019, 02:34 PM   #3
Ronnieroadster
Ronnieroadster's Avatar
I remove those tubes by running a tap into them and then with the tap still in the tube I hold the tap in the jaws of the bench vise and then gently tap the Stromberg carb body with a soft hammer those tubes always come out doing it this way. Removed many of them when converting to alky for one of the race cars i always had to open up the dump tubes to really big sizes for more speed and power good times for sure..
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 03-23-2019, 04:51 PM   #4
flathead34
flathead34's Avatar
Ronnieroadster: Thanks for the tip. I will try removing them using the tap method. Mike
Old 03-23-2019, 05:02 PM   #5
Flathead Fever
Flathead Fever's Avatar
Somebody is selling a tool kit to remove them on eBay. I don't have any info on how well it works?
https://www.ebay.com/itm/STROMBERG-9...-/360403282749
Old 03-23-2019, 10:56 PM   #6
quickchange34
quickchange34's Avatar
It takes a 8-32 tap. Cut the threads first , not to deep ,about 4 or five turns of the tap. handle. You will need a 8-32 machine screw 1 1/2 inch long . install a 8-32 nut on the screw with a 10 flat washer . Install screw into the tube and tighten the nut down against the flat washer pulling the tube out of the carb body.
quickchange34 is offline   Reply With Quote
Old 03-24-2019, 08:56 AM   #7
Mike51Merc
Mike51Merc's Avatar
Does anybody know if tapping threads in the tube will change its flow characteristics?
I've removed tubes before, but only to replace them with new ones. Was wondering if the old ones with the threads were ruined.
Mike51Merc is offline   Reply With Quote
Old 03-24-2019, 01:18 PM   #8
flathead34
flathead34's Avatar
Flathead Fever: I decided to try out one of those kits you suggested. Looks like that is the method suggested by Quickchange34. Thanks, Mike
Old 03-24-2019, 01:35 PM   #9
1952henry
1952henry's Avatar
That kit looks just like what has been described above. If you have an 8-32 tap and handle, a $1.50 for a screw, my, and washers would be cheaper. I've used the tap/machine screw method before several times. Works great.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 03-24-2019, 01:52 PM   #10
uncle max
uncle max's Avatar
Actually 6-32!
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 03-24-2019, 02:04 PM   #11
1952henry
1952henry's Avatar
Oops. Been awhile since I've dug my little puller out. Thanks for correction.
Old 03-24-2019, 11:14 PM   #12
quickchange34
I will correct as well I looked at the tap I use this morning and its a 6/32 and a 6/32 screw .
Old 03-24-2019, 11:28 PM   #13
JM 35 Sedan
JM 35 Sedan's Avatar
Originally Posted by uncle max View Post
Actually 6-32!
Max, thanks for clarifying tap size.
I think it was nearly 15 years ago that you shared your method for pulling emulsion tubes and a few of your other secret weapons for rebuilding Stromberg carburetors with us Fordbarners.
John
