09-22-2015, 06:36 PM | #1 |
Electric fuel pump in shuebox
When you cut the fuel line to install the fuel pump due you flair the fuel lines. According to Airtex they should be flared. Problem is I do not have a flaring tool
09-22-2015, 06:48 PM | #2 |
Re: Electric fuel pump in shuebox
Depends on how you are connecting it. If you are using short pieces of hose on each side you the pump all I normally use is clamps. If you are using hard fittings I would use flair fittings. Ether way this is a low pressure setup.
09-22-2015, 07:10 PM | #3 |
You are only running 3 psi max I would presume, so a clean deburred cut with a quality stainless hose clip will be ok. Put the filter before the pump.
09-22-2015, 08:23 PM | #4 |
As noted in an earlier post, using rubber hoses to connect the electric fuel pump to the gas line and filter will serve to mitigate the noise from the pump.
09-22-2015, 09:00 PM | #5 |
Thanks guys. Did not think I would need to flare the gas lines. But figured I would ask the experts to be sure so I would not have problems down the road.
09-22-2015, 09:52 PM | #6 |
09-22-2015, 10:58 PM | #7 |
Here is how I installed the electric fuel pump in my shoebox with compression fittings - easier than flared and more secure and durable than rubber hoses clamped on.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 09-22-2015 at 11:41 PM. |
09-23-2015, 12:33 PM | #8 |
pump should be mounted as close as possible to the tank. Mine is bolted to the spare tire well (using the Mustang tank turned sideways)
09-23-2015, 12:41 PM | #9 |
Nice thing about rubber and hose clamps - you can clamp off to changes inline filter
09-23-2015, 01:24 PM | #10 |
If you do use hose, buy fuel injection type. CORN GAS WONT EAT IT UP.
MNSHNR |
09-23-2015, 01:53 PM | #11 |
You probably know, but here it is anyway, even though you have the filter just before the pump, you should still have one up just before the pressure regulator (if you have one).
