Old 01-11-2018, 05:08 PM   #1
Robin 47 ford pickup
Default 47 ford pickup cowl vent seal
Hi guys can anyone tell me if the cowl vent seal on a 47 ford pickup is attached to the cowl or the vent door , why I ask is my truck did not have a seal when I got it and to glue it to the vent door it is to long and wide . Plus if I sit the seal in the tray where the vent door shuts into the and you close the vent it sits up as if the seal wont compress . does the vent door simply sit on top of the seal? I have used a Denis Carpenter seal . is there a better fitting softer seal out there? any help would be great
cheers Robin Gregory
Robin 47 ford pickup is offline   Reply With Quote
Old 01-11-2018, 05:25 PM   #2
skidmarks
skidmarks's Avatar
Default Re: 47 ford pickup cowl vent seal
It goes in the tray area of the body. New ones will eventually compress but when first installed the are swelled up and hold the lid up alittle. If you can get it closed completely try parking it in the sun light.
Thats when i have run into with a carpenter seal. Not sure if there is a better one to use
skidmarks is offline   Reply With Quote
Old 01-11-2018, 06:32 PM   #3
JSeery
JSeery's Avatar
Believe it is fairly common to have to trim the height (off the bottom side). As already stated, they mount into the cowl.
