Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 01-10-2018, 09:25 PM   #1
Robin 47 ford pickup
Default 47 ford pickup cowl vent seal
Hi guys can anyone tell me if the cowl vent seal is attached to the cowl body itself or to the vent door ? Why I ask is because my truck had no seal when I got it and the seal I bought is to big/long to be glued under the vent door , and does the vent door rest on top of the seal if it is glued to the cowl ? problem there is the vent door will most likely sit proud of the cowl as it will take a fair amount of pressure to squash the seal . please help me
cheers Robin
Robin 47 ford pickup is offline   Reply With Quote
Old 01-11-2018, 01:48 AM   #2
Charlie Stephens
Default Re: 47 ford pickup cowl vent seal
You posted your question in a forum intended for questions "To The Editors". This forum is seldom read. You need to repost in the main forum, https://www.fordbarn.com/forum/forumdisplay.php?f=4
Best of luck
Charlie Stephens
