Old 10-17-2021, 07:44 AM   #1
Bustingear
Default Need help with 3 items needing ID.
Need help with ID on these items ...Generator, Motor mounts and other mounts
I suspect the products are from Ford flathead 1949-1953 but not exactly sure of year make and model and would like to pin it down. Thanks!
Bustingear is offline   Reply With Quote
Old 10-17-2021, 08:02 AM   #2
alanwoodieman
Default Re: Need help with 3 items needing ID.
1953 Ford pick up front motor mount- u shaped item, generator from same, other motor mounts look to me like chevy or maybe rear mounts for 53 pu--I need to look at 53 motor/trans I have in the shed
Old 10-17-2021, 08:12 AM   #3
Charlie ny
That horse collar front mount is a one year only item....always missing when going back
to flathead power from an OHV swap.
Charlie ny
Old 10-17-2021, 08:49 AM   #4
Bustingear
i think the mounts might be car but there are two different ones??
Old 10-17-2021, 09:15 AM   #5
rotorwrench
rotorwrench's Avatar
That's what I was thinking about the two separate mounts. They look to be water pump front mounts from an 8BA family vehicle. The generator fan/pulley prefix dates back to the original H model 6-cylinder but was used on later generators as well.
