Old 02-02-2013, 05:26 PM   #1
A31Woody
A31Woody's Avatar
Default Fitting New Front Spring
I purchased a new spring a while ago. The catalog said:
"The top leaf sides may at times need to be slightly tapered to fit within crossmember."
I haven't taken the old one out yet, as I'm hoping to do it in one shot. I have the new spring broken down right now and would like to grind it down prior to painting and lubing.
How much should I grind down on the sides?
A31Woody is offline   Reply With Quote
Old 02-02-2013, 06:40 PM   #2
TinCup
TinCup's Avatar
Default Re: Fitting New Front Spring
What you are trying to do is prevent the spring from digging in the spring below. Just champer the end of the spring so when it is compressed it doesn't dig in. Also go to Napa and buy yourself some slipplate it is great stuff to paint the spring with.
TinCup is offline   Reply With Quote
Old 02-02-2013, 07:02 PM   #3
lindy williams
The instruction you quoted is referring to the top leaf of the spring. The outside edges of the top leaf need to be chamfered to fit the shape of the front crossmember of the car frame.
lindy williams is offline   Reply With Quote
Old 02-02-2013, 07:03 PM   #4
A31Woody
A31Woody's Avatar
Right... wondering how much they need to be ground down prior to painting.
Old 02-02-2013, 07:08 PM   #5
Rusty Homestead Fl
Rusty Homestead Fl's Avatar
You may want to bevel the sides of the top leaf so it will seat properly in the cross member.
Rusty Homestead Fl is offline   Reply With Quote
Old 02-02-2013, 07:13 PM   #6
ScottNW/Ohio
ScottNW/Ohio's Avatar
Grind off about an 1/8" off the front and rear of the top leaf
Some replacement springs are wider than originals, this helps it 'seat' in the crossmember
ScottNW/Ohio is offline   Reply With Quote
Old 02-02-2013, 07:18 PM   #7
A31Woody
A31Woody's Avatar
Originally Posted by Rusty Homestead Fl View Post
You may want to bevel the sides of the top leaf so it will seat properly in the cross arm
Just what I needed. Thanks!
Old 02-02-2013, 10:07 PM   #8
wrndln
Why don't you just clean up the top leaf of the old spring that is already tapered and install it on the new spring?
Rusty Nelson
Old 02-03-2013, 12:42 AM   #9
lance leblanc
lance leblanc's Avatar
Should'nt a piece of oiled leather or welt be inserted on top of the new spring before installation?
lance leblanc is offline   Reply With Quote
Old 02-03-2013, 06:01 AM   #10
Steve Wastler
Steve Wastler's Avatar
No.
Steve Wastler is offline   Reply With Quote
