04-11-2020, 09:12 AM | #1 |
1936 firewall differences - pickup/car
The Early Ford V8 Club 35/36 book, page 10, has a perfect depiction of the car firewall. I assume the 36 pick-up firewall would be absolutely identical. Before I buy a pick-up firewall, can someone verify an exact fit for the coupe? Thanks in advance.
04-11-2020, 09:17 AM | #2 |
Re: 1936 firewall differences - pickup/car
I'd assume the pickup would be completely different than the passenger car.
04-11-2020, 09:43 AM | #3 |
The cowl on a pickup is different than the cowl on a passenger car. So the firewall is also different. Buy a passenger car firewall if that is what you need.
04-11-2020, 10:22 AM | #4 |
Thx
04-11-2020, 06:07 PM | #5 |
Thanks TJ. I just couldn't imagine the car and PU being the same.
04-12-2020, 09:56 AM | #6 |
04-12-2020, 10:03 AM | #7 |
Thanks Don.
04-12-2020, 10:24 AM | #8 |
A big, obvious difference is the recesses of the upper half is significantly shorter (on the order of 2") on the pickup. It can be easily seen on Don's photos.
04-12-2020, 10:43 AM | #9 |
Thanks to Don and Karl for the additional info.
