12-16-2012, 07:18 AM | #1 |
Wrapping the rims on kelsey hayes spoke rims
I would like to talk to someone that has used the black puumbers tape to cover the spoke nubs on the inside of the wire wheel. This allows the use of tubes with the radial tires. Each rim has the sprayed on black material covering the spoke nubs. Where do I go from here ?
Thanks to All |
12-16-2012, 10:39 AM | #2 |
Re: Wrapping the rims on kelsey hayes spoke rims
the complete inside of the rim needs to be smooth, sanded and painted , never used plumpers tape, always use duct tape, the inside of the rim needs to be smooth because the tube flexes a lot when rolling with radial tires, dont want any rough edges inside the rim to wear on the tube, also use lots of talcum powder inside the tire for the same reason, radial tires really flex and can be hard on tubes
12-16-2012, 11:47 AM | #3 |
may i suggest cutting an old truck inner tube across the tube and it pull over the rim like a rubber band it has worked well for me. You still will want tp prep the rim as mentioned above. Frank
12-16-2012, 08:02 PM | #4 | |
Alan H. Tast AIA, LEED AP BD+C Technical Director/Past President-Editor-Publications Director, Vintage Thunderbird Club Int'l. (VTCI) http://www.vintagethunderbirdclub.net Author, "Thunderbird 1955-1966" & "Thunderbird 50 Years" 35+ year member, Crown Victoria Ass'n. |
12-16-2012, 10:30 PM | #5 |
63bird, i worded my post wrong, i meant to say i never use plumbers tape, i use duct tape because it sticks to every thing real good
12-18-2012, 10:10 PM | #6 |
Thanks for Everyone's help. |
12-19-2012, 08:33 AM | #7 |
A followup to my above message. Yes, I preped each rim by sanding roughspots, painting, powdering the tire and tube. After installation of the Truck Tire
Bands I did a small amount of trimming on the band to keep it from curling up on the side to interfere with the tire. I do have two rolls of plummers tape if someone can give me a good use for it. THANKS AGAIN FOR ALL THE HELP |
12-19-2012, 08:44 PM | #8 | |
If brains were wire, some couldn't short circuit a firefly |
12-21-2012, 07:53 AM | #9 |
CAUTION for everyone using duct tape as a wheel liner
The first wheel I did was a reconditioned wheel I had restored. the next two I took off the car were banded with duct tape. One wheel had a small amount of duct tape that had been moved by the tube and kind of wadded into a little ball. Where this ball rubbed the tube it had started to wear thru the rubber. If you use duct tape make sure no sticky side of the tape is exposed on the edge that the tube can contact. I really ljke the inner tube bands. The best way to put the bands on is with two people. |
12-23-2012, 05:49 PM | #10 |
K-H offered liners to go with the wheels.
If using a radial tire, also use a radial tube.
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
