11-03-2021, 06:28 PM | #1 |
Eddie Meyer Intake, No Fan Mount
I am looking to use the 2x2 Eddie Meyer low profile intake on a 1952 EAB. This intake does not have any provisions for the generator or fan. Is there a work around for this issue?
Flathead Flatfender |
11-03-2021, 07:37 PM | #2 |
Re: Eddie Meyer Intake, No Fan Mount
At one time there was a bolt on bracket available that mounts on top of the intake at the front using the first two bolt holes on each side. This bracket has a stud in the center for mounting the fan and generator bracket. The last one I came across was years ago at the Ford Store in San Demas California Bill would not let it go extremely to hard to find. The bracket to my knowledge has never been reproduced the original brackets are rare but there must be some around.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH Last edited by Ronnieroadster; 11-03-2021 at 07:42 PM. |
11-03-2021, 07:44 PM | #3 |
Check with Speedway. The still list a cylinder head generator mount for a 37-48, may have one for a later flathead. You may be able to use it with the angled water neck
48 Ford Conv 56 Tbird 54 Ford Victoria Last edited by paul2748; 11-03-2021 at 07:51 PM. |
11-03-2021, 07:56 PM | #4 |
Weiand made one that would bolt on the top of that in the front.
Wayno
Life is not a spectator sport. |
11-03-2021, 08:16 PM | #5 |
11-03-2021, 08:58 PM | #6 |
11-04-2021, 01:33 AM | #7 |
Yes, I am already planning on using a PCV system.
11-04-2021, 01:41 AM | #8 |
Does someone know of similar low profile intake ? I am looking for the shortest intake/carb combo available. Height is going to be a close one for the destination vehicle. I would rather not cut a hole in the hood.
11-04-2021, 02:11 AM | #9 |
from another current thread...I have no affiliation with the seller
https://www.facebook.com/marketplace...7-0899e65b2fa4
11-04-2021, 09:35 AM | #10 |
The front carb bowl won't allow a generator on manifolds like that but may allow a bracket for an offset fan mount. Offenhauser had offset generator mounts that fit the intake bolts and head bolts with right or left options on some but they may be limited on an Eddie Meyer set up. A person can fabricate an on center fan mount set up and use an offset generator mount. Speedway carries some of that type stuff.
https://www.speedwaymotors.com/Searc...rator%20mounts |
11-04-2021, 10:00 AM | #11 |
My Weiand had one of those, aftermarket I think.
11-04-2021, 10:46 AM | #12 |
Check with Vern Tardel
11-04-2021, 01:30 PM | #13 | |
The lowest two carb intake is the Almquist it measures 2-1/4 high. You can see from the photo the three intakes that include the front mounting location. The Burns intake has the carbs set closer together so the generator can be located in the stock location. Each of these intakes are available if interested send me PM. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH Last edited by Ronnieroadster; 11-04-2021 at 02:20 PM. |
11-04-2021, 04:57 PM | #14 |
This is a picture of what I have. Good luck
11-04-2021, 07:18 PM | #15 | |
11-04-2021, 09:52 PM | #16 |
No so far any only others I have seen have been like the one I have.
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
11-05-2021, 10:48 AM | #17 | |
11-05-2021, 01:31 PM | #18 | |
Your welcome
11-05-2021, 04:12 PM | #19 |
Thanks Ron I have a pristine Burns with risers & super rare generator riser. I have only seen one other & it had risers but didn’t know if it was a regular thing. I thought I had read somewhere they all had risers. Thanks Ron.
11-05-2021, 06:53 PM | #20 |
Well I don't have enough posts to send you a pm Ronnie.
