One original set of 2nd generation headlight lens. This is a matching set that came off the same car. Both lens has the Ford oval at the bottom with an H right below the Ford. Both lens has the following numbers at the bottom ( A-13060 M C K ). The one lens has a smaller C than the other. One lens I cannot find any chips or imperfections. The second lens has one tab about 2/3 broken off. The broken area on the tab would not show when mounted. This same lens has two tiny stone chips.
