Old 11-07-2021, 09:53 AM   #1
RalphM
RalphM's Avatar
Default Does the oil pump bolt have to be safety wired?
I just put the pump in with original bolt/ new lock washer. Then I got to thinking about all the ones I’ve seen with a a hole for the wire. This one does not have it, but I torqued it down to specs.
Should I be worried?
RalphM is offline   Reply With Quote
Old 11-07-2021, 10:10 AM   #2
DavidG
DavidG's Avatar
Default Re: Does the oil pump bolt have to be safety wired?
I'd find a bolt with a hole in the head or drill one in the head of your present bolt. Generally speaking there is a good reason why they were safety-wired in the first place, at least on all of the early ones.
Old 11-07-2021, 10:50 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
Why take the chance that if that bolt comes loose, and falls into the oil pan, it has the potential to tear up something in that lower end that can/will ruin the engine.
John
Old 11-07-2021, 11:06 AM   #4
Juergen
Except for race cars and airplanes, does anyone safety wire bolts if they also use lock washers? Car manufactures find that properly torqued bolts with lock washers exceed the 100,000 mile warranties so are unnecessary. Once the bean counters took over at Ford after the war, safety wiring disappeared in the new models. Should you be worried? Not unless you need redundancy to be care free.
Juergen is offline   Reply With Quote
Old 11-07-2021, 11:51 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
Pumps to '48 used a drilled head bolt.
'49-'53 manual shows bolt and lock washer only.
It's like wearing a belt and suspenders.
For peace of mind you can wear the suspenders (safety wire)
Old 11-07-2021, 12:21 PM   #6
RalphM
RalphM's Avatar
I’m a belt and suspenders kinda guy!
Old 11-07-2021, 12:27 PM   #7
rotorwrench
rotorwrench's Avatar
Ford used safety wire in the times up to and just after WWII. They didn't use the annealed stainless wire like we use in aviation but it worked just the same. They even used a lot more cotter pins in the early years.
Old 11-07-2021, 12:29 PM   #8
Brian
Brian's Avatar
I use loctite
Old 11-07-2021, 12:47 PM   #9
RalphM
RalphM's Avatar
I tried to find my Loctite before putting it in, but I have no idea where it is.
I’m thinking I’m gonna pull it back out and drill a hole through the head.
Old 11-07-2021, 04:51 PM   #10
JM 35 Sedan
Great idea!! I can't tell you how many broken/non functional lock washers I've found while working on these old Fords in the last 63 years.
John
Old 11-07-2021, 05:03 PM   #11
deuce_roadster
deuce_roadster's Avatar
Lock washers are single use items. Not to be reused. Ask the airplane guys.
Old 11-07-2021, 07:19 PM   #12
J Franklin
J Franklin's Avatar
During the depression everybody reused things that looked ok. I agree they are one use items. I use LockTite and washers for looks.
Old 11-07-2021, 07:24 PM   #13
J Franklin
J Franklin's Avatar
Old 11-07-2021, 07:42 PM   #14
DavidG
DavidG's Avatar
The problem with using Loctite in that application is the necessity for the threads in the block (and obviously on the bolt) to be dry and completely free of oil. Oil is an ingredient of the assembly process for a rebuilt engine and the odds of some ending up in that hole in the block are not zero.
Old 11-07-2021, 08:01 PM   #15
J Franklin
J Franklin's Avatar
Contact cleaner with a straw nozzle is the way I do it. I use LockTite on every fastener I use, except wood and sheetmetal screws! I use safty wire and cotters on places that they are intended along with LockTite.
Old 11-07-2021, 08:10 PM   #16
Ronnieroadster
Ronnieroadster's Avatar
On the engines I build I use the safety wire no matter what year flathead it is.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 11-08-2021, 10:01 AM   #17
JM 35 Sedan
Good advice in general Ronnie, and especially good advice for anyone attempting a record run at Bonneville @ 200+ mph. What was your approximate engine rpm @ 205.744 mph?
John
Old 11-08-2021, 10:09 AM   #18
drolston
drolston's Avatar
What is the proper way to safety wire the bolts holding the differential carrier together? The safety wire that I cut off to replace an axle was tightly twisted double wire by some tool that I do not have. So far I have just run a single galvanized steel wire around through all of the bolt heads, and twisted the ends together. With that, no bolt can make more than an eighth of a turn. Good enough?
Old 11-08-2021, 10:14 AM   #19
JM 35 Sedan
Most of the broken, non functional lock washers I mention in post #10 were on original cars being dismantled for the first time. Probably the only thing that kept that hardware together was rusty threads.
John
Old 11-08-2021, 11:32 AM   #20
Crankster
Crankster's Avatar
Default Safety wire
Safety wire or "wire twister" pliers are not really necessary, don't let that trip you up. Their primary utility is for long open runs.
I did a LOT of safety wiring in the .mil and only rarely used them. Like modern cars there is oftentimes very, very little room to work in and unfortunately the pliers were absolutely useless most of the time. Safety wiring does take practice, but the pliers are not critical to the task.
The idea is that the bolt or fastener will not loosen, (or wire installed in the loosening direction!) no nicks or excessive work hardening of the wire, and no sharp edges to cut or catch "pigtail" etc. There are even accepted practices for installing the lowly cotter pin. Search "safety wire techniques" for some instruction.
Crankster is offline   Reply With Quote
