10-31-2017, 06:52 AM | #1 |
early 1933 air cleaner?
Is this an early 1933 air cleaner?
10-31-2017, 07:01 AM | #2 |
Re: early 1933 air cleaner?
Used all model year long, carried over from '32.
11-01-2017, 05:29 PM | #3 |
What is the diameter of the air cleaner and what kind of element does it use?
people have more trouble than anybody |
11-02-2017, 04:38 PM | #4 |
I use a Baldwin. PA1859 or a WIX 46641
Dave |
11-14-2017, 07:40 PM | #5 |
Does anyone have breakdown drawing of the parts of this 1933 air cleaner?
11-14-2017, 08:58 PM | #6 |
11-14-2017, 11:07 PM | #7 |
The made in Canada tapered side version of the subject air cleaner is unique to Ford of Canada models through the '34 model year, hence their presence on Fords in the Commonwealth countries, where with the exception of the U.K. the Ford operations were Ford of Canada subsidiaries. The U.S. version with more vertical sides was made by Holley and used in both the '32 and '33 model years. The dome-shaped Burgess air cleaner appears to have been confined to the '32 model year in the U.S.
11-15-2017, 07:05 AM | #8 |
I think this is the 1932 version
11-15-2017, 07:38 AM | #9 |
Engine drawings from original owners manuals
But, in the 1933/34 restoration manual I see the straight vertical side air cleaner Could my owners manuals be Canadian? Last edited by FrankWest; 11-15-2017 at 08:12 AM. |
11-25-2017, 05:10 PM | #10 |
FrankWest, your owners manuals will say Ford Canada on the cover if they are. Plus the 34 Canadian manual will show the 33 air cleaner.
11-25-2017, 05:54 PM | #11 |
My 1933 and 1934 instruction books say only ford motor company on the front.
Funny, the 1933 air cleaner body is slightly tapered just like on the photot in your book. Yet, the air cleaner pictured in the beginning of this thread clearly is not tapered. I guess it is not all that important, maybe ford used one photo for all books, but still shipped american made cars with the more cylindrical air cleaner. |
11-25-2017, 07:56 PM | #12 |
On second thought, that air cleaner in the first photo may not be an example of the version used by Ford. I've numerous examples of '32-'33 air cleaner and they all have tapered sides consistent with the illustrations in both the Canadian and U.S. owners manuals. There is one minor difference between those two shown in the owners manuals and that is how the top section of the air cleaner is attached to the bottom section. The Canadian illustration shows a wing nut which is obviously attached to a stud, but only the very earliest U.S. '32 version had a stud (and acorn nut) for the attachment of the top and bottom sections. All of the others are held together with a slotted round head screw and of course there is no stud.
11-25-2017, 09:15 PM | #13 |
Here is a photo of the air cleaner I have just restored. It has a slot headed screw that threads into the bottom section. The screw is not in this photo, I have to drill and tap the lower portion to accept the screw, but it came with the original slotted screw that broke off in the lower portion, but I was still able to determine the proper thread size
11-26-2017, 01:31 AM | #14 | |
11-26-2017, 06:59 AM | #15 |
Sheldon,
It would appear so as confirmed by the photo below from Ford's Archives. |
11-26-2017, 03:24 PM | #16 |
This the air cleaner on our N.Z 1932 3/W
11-26-2017, 07:27 PM | #17 |
Did the 1933 ford USA Air cleaner have a decal?
11-26-2017, 07:53 PM | #18 |
Good question! The '32 version did like shown in Ian's photo. A decal is absent in the Archives photo and normally such a decal would be on the left side.
11-27-2017, 09:20 PM | #19 |
Here is a photo of what looks like a 33, even aluminum heads and this air cleaner looks thinner. Interesting. Note the 2 blade fan? experimental? Didn't a 33 have a 4 blade fan?
11-27-2017, 09:25 PM | #20 |
This is a cool little photo. Experimental V8 likely taken in 1931 (correct me if wrong). Note the one single exhaust port, and starter motor location.
