Old 09-18-2020, 09:14 PM   #21
1930-Pickup
Default Re: Dual Condensers?
Originally Posted by Pete View Post
It depends on the primary supply voltage, the individual coil, capacitor and the rpm (interrupt frequency) what the voltage spike will actually be. I have measured 300+ on a scope.
If you are worried about capacitor quality, try one of those brass things Tubman makes. They seem to match most coils found on model A's.
Thanks Pete. You got the numbers, you're the man!
I always worry about product Quality...it's fused into my DNA.
I'm not familiar with Tubman. They make caps?
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 09-18-2020, 09:28 PM   #22
Pete
Pete's Avatar
He is on this forum. You can find him in the member list.
Old 09-19-2020, 09:20 AM   #23
rotorwrench
rotorwrench's Avatar
He reproduces the type made by Mallory for it's aftermarket ignition systems. Some call them the trash can type due to it's size and shape. This is what they look like.
https://www.jalopyjournal.com/forum/...nsers.1037842/
They are pretty large for a model A application. The Vertex Scintilla magneto condensers are another well made cap that folks sometimes use but all of these are expensive. Napa Echlin still manufactures fairly decent condensers but I don't know how much longer that will last after they were bought out by Standard Motor Parts. I always buy two or three to make sure I get at least one good one.
Old 09-19-2020, 02:55 PM   #24
Pete
Pete's Avatar
You could mount it under the dash if you didn't like the looks.
Old 09-19-2020, 08:11 PM   #25
Bill Pursel
Bill Pursel's Avatar
Alot of motorcycles had the condenser mounted up under the fuel tank away from the points and worked fine.
Bill Pursel is offline   Reply With Quote
Old 09-20-2020, 02:07 PM   #26
Patrick L.
Patrick L.'s Avatar
Yep, as said, those electrons are quick little buggers. They don't much care.
Old 09-21-2020, 07:56 PM   #27
KGBnut
KGBnut's Avatar
Thanks to all of you. This forum is a wealth of information.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
