Old 06-06-2020, 10:07 PM   #1
zoegrant
zoegrant's Avatar
Default Missing hand throtle part
On my 36 coupe which has a flathead with a Ford EAB carb there was a piece that connects the hand throttle rod to the carb...well it fell off on a ride the other day. The missing part appeared to be bronze or brass and was shaped like a little helmet and inside was a spring. This little helmet fit over a( T )shaped piece that the hand throttle rod is hooked to.
Anyone know what I am talking about ? If so, where can I get one and what is it called ?
zoegrant is offline   Reply With Quote
Old 06-06-2020, 10:33 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: Missing hand throtle part
Zig you will need to buy the whole length of rod that is joined under the dash its about 3 ft and crimped to the dash knobs ,any early Ford suplier such as Carpenter ,Macs ,Speedway ,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 06-07-2020, 06:20 AM   #3
Terry,OH
Terry,OH's Avatar
Vintage Speed has nearly all the parts for the 94. Check out their web site. What ya doing with a EAB on a 36? How about a photo of your engine.
Old 06-07-2020, 06:25 AM   #4
deuce lover
deuce lover's Avatar
This what you need?
Old 06-07-2020, 07:06 AM   #5
GaryU.
GaryU.'s Avatar
If what deuce posted is the part (my thoughts as well), you should contact CharlieNY as he probably has a box of them for his carb repairs.
GaryU. is offline   Reply With Quote
Old 06-07-2020, 08:23 AM   #6
tubman
tubman's Avatar
And it bears repeating again. "Charlie NY" will serve you a LOT better than "Charlie Price" (Vi8ntage Speed).
Old 06-07-2020, 04:48 PM   #7
terry
Help me out deuce lover, does that end piece on the right also have holes in it to put a holder through, as well, to keep it from falling off the shaft? At least that is what's on my throttle at the carb on my 36. A cotter pin will suffice here.
terry is offline   Reply With Quote
Old 06-07-2020, 10:20 PM   #8
zoegrant
zoegrant's Avatar
Thank you Deuce...just what I needed....bought one on Ebay….
Old 06-07-2020, 10:22 PM   #9
scicala
scicala's Avatar
The piece on the right is slotted inside the hole. You push it in against the spring/lever and then rotate it 90 degrees to lock it on the throttle shaft.
Sal
scicala is offline   Reply With Quote
Old 06-08-2020, 06:40 AM   #10
Terry,OH
Terry,OH's Avatar
The above parts are for the 94 if you have a Stromberg they look like the pieces below which use a tapered pin to fit into a hole in the throttle shaft for attachment.
Old 06-08-2020, 08:00 AM   #11
terry
Yes, that's my set-up on my Stromberg 48. Thanks, Terry. Didn't mean to confuse people. terry
