Old 02-19-2020, 12:17 PM   #1
Turbo26T
Default Trunklid to tulip panel gap
'31 Std coupe (45B)
Im using a repop trunklid and it was not drilled for hinges. Whats a good ballpark gap between frt edge of lid and tulip panel.. Ready to drill for hinges and would like to be as correct as possible before drilling. Pictured gap is 1/4" +/-
Seems to be some adjustment on hinges for flush fit up & down ,but not forward and backward to correct gap
Any real experiences appreciated
Turbo26T is offline   Reply With Quote
Old 02-19-2020, 07:05 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Trunklid to tulip panel gap
1/8”-3/16” max
Usually the repo deck lid is too wide and rubs on the sides
Old 02-19-2020, 09:49 PM   #3
Turbo26T
Oldbluoval: Thanks for the info...I thought 1/4" looked a bit wide..so ill tighten it up a bit..
1/8 - 3/16 will be my target
My lid actually fits well on the sides and does not rub..
Stan
Old 02-21-2020, 08:08 AM   #4
Fomoco998
Looking at your picture when you correct that gap your side to side gap will change allot . Fitting new parts on something 89 years old is a task .
Fomoco998 is offline   Reply With Quote
Old 02-22-2020, 12:00 AM   #5
Drive Shaft Dave
Smile Re: Trunklid to tulip panel gap
Originally Posted by Turbo26T View Post
'31 Std coupe (45B)
Very interesting term, I had not heard that panel call the tulip panel before.
Drive Shaft Dave is offline   Reply With Quote
Old 02-22-2020, 08:43 AM   #6
Oldbluoval
Oldbluoval's Avatar
Been around a’’s 59 years and never heard that term either!!
Old 02-22-2020, 09:15 AM   #7
Steve Plucker
Steve Plucker's Avatar
Me neither...Can you enlighten us on where the term "tulip panel" came from?
Hmmmmm???? Model T's maybe?
Thanks.
Pluck
www.plucks329s.org
Walla Walla (WA) Sweet A's since 1993
MARC/MAFCA member since 1978
Ford Model AA Truck Club since 1998
(LIONEL/MTH Toy Train Collector, Orange Crush Soda Collector, Steel Beer Can Collector, Old Gas Pump Collector)
Old 02-22-2020, 10:03 AM   #8
Turbo26T
Google "Ford tulip panel " ....Click on "Images "...Bada bing !!
You guys need to get out more....!
Old 02-22-2020, 01:24 PM   #9
Oldbluoval
Oldbluoval's Avatar
Every time I “get out more”
I find I was happier under my rock!
Sure nuff that term is prevalent if you search it
Back to my rock!!
Old 02-22-2020, 04:54 PM   #10
Turbo26T
Wonder what Ford called that panel....if you went to a Ford dealer back in the day , what did the parts book list it as??
I have no idea why its called a tulip panel....thats just the term i found when i was looking for one a few years ago....
Old 02-22-2020, 06:42 PM   #11
Steve Plucker
Looking in the November 15, 1929 Body Parts List...here is what the Ford dealer would of seen "back in the day":
For Roadsters it was A-41405 Panel (deck) assembly---Upper;
For all Coupes it was A-47405 Panel (deck) assembly---Upper.
Pluck
www.plucks329s.org
Old 02-22-2020, 06:52 PM   #12
rotorwrench
rotorwrench's Avatar
It's usually referred to as the panel above the deck lid. Folks always like to attach new terms to shorten or abbreviate long descriptions. Tulip doesn't jump right out and explain why it's called that. It has more than two lips so that doesn't really explain it either. Forgive us old farts for using actual descriptions in reference. This way there is no confusion.
What do they call the panel below the deck lid if I may ask?
Old 02-22-2020, 07:14 PM   #13
Bob C
"What do they call the panel below the deck lid if I may ask?"
Looks like 28-29 A-47421-AR Panel (deck lower) and 30-31 A-47421-B Panel (deck lower)
Old 02-23-2020, 04:05 PM   #14
Turbo26T
All this info and comments about the actual name for the panel and only one reply answering my original question... The gap between the _____ ( insert panel name you prefer ) and the upper edge of the trunklid/decklid..I'm having to drill all hinge mount holes and hoping to get them as close as possible....Don't want the lid to rub on the (whatever you prefer) panel , so I'm gonna shoot for 1/8"-3/16" as Oldbluoval kindly recommended
Thanks anyway for all replies...
BTW : I'm an old-timer myself..Turned 78 last November...strating to question my sanity in starting this coupe project...!!!
Stan
Old 02-23-2020, 06:28 PM   #15
rotorwrench
Some of these old cars have had a rough life. Quarter panel damage or rear end damage can get things out of kilter. The other problem mentioned is quality of new replacement parts. They can be close but not close enough. It really helps when you have some old original parts to study. This is the best way to find out what dimensional differences might be.
I have heard of folks having to cut the metal on both right and left edges to reduce the width of parts that didn't fit the original opening. So far, I haven't heard of anyone having to add metal to any edge but then again, anything is possible. Many of the replacement panels below the deck lid have had fit problems over the years. This will affect deck lid fit too. It pays to get the best parts possible. I tend to repair parts before replacing them even if I have to cut them apart to do it. With missing parts, then a person is at the mercy of the supplier.
Your fit dimension 1/8" to 3/16" is pretty close. Ford used gap gauges to check fit and finish during assembly.
Old 02-23-2020, 10:45 PM   #16
Tinbasher
Tinbasher's Avatar
The Gap top and bottom is usually about 3/16 to 1/4. Always a bear to get the alignment. I've done at least a dozen of them and they always take time. Original hinges help alot. I worked ina English restoration shop and they used the term "Tulip panel" as well as wing, boot and bonnett. (Fender, Trunk lid and Hood)LOL!!
Tinbasher is offline   Reply With Quote
Old 02-23-2020, 11:10 PM   #17
Russ B
The required gap may be controlled by the need for sufficient clearance between the pieces when opening and closing the lid. You don’t want a perfect looking tight gap that will rub off the paint when you open the trunk lid. It take a bit of fitting to get it right, and be sure there is extra space to allow for paint thickness.
Russ B is offline   Reply With Quote
