07-01-2023, 10:19 AM | #21 |
Re: Choice of two holes for mounting rear spring?
She handles like a labrador on linoleum. A later model track bar is on the shopping list.
07-01-2023, 12:43 PM | #22 | |
I added the late rear track bar to my '41 Merc and it helped a lot. Also replaced everything in the front suspension that had any wear at all...like the "sway bar" swivels and bushings in particular. I wanted to add the late front track bar but there just isn't enough room to do it properly. I really tried but the axle perch and frame mounts are just not compatible. I even made one that attached behind the axle but couldn't get the geometry close enough to prevent bump steer. However, after replacing all the worn front steering/suspension parts and replacing the original worn steering box with a GM 525 box it's really nice. Finally! Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
07-01-2023, 10:36 PM | #23 |
Which track bar did you fit?
07-01-2023, 10:40 PM | #24 |
07-02-2023, 04:18 AM | #25 |
Many thanks
07-07-2023, 03:33 PM | #26 |
Terry p.s. Fortyonerag-your axle perches sure look like '40 to me. I'm no expert though....
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 Last edited by cadillac512; 07-07-2023 at 03:43 PM. Reason: more info |
07-07-2023, 04:32 PM | #27 | |
07-07-2023, 07:34 PM | #28 |
Many thanks Terry, this will help a lot.
You might be right about my spring perches, part of having a car that's an 'Older Restoration', I suppose. Sometimes a child of many fathers..... |
07-08-2023, 07:06 AM | #29 |
Appears that forty41rag incorporates a reversed eye spring, & really don't see a great shackle attitude difference from the initial post to the comparisons posted.
