Old 01-31-2017, 08:41 AM   #1
old46ford
Default Horn question - 46 coupe
I am rewiring my car and one of the things left to finish is the two trumpet horns... the cloth covering is gone and the wires exposed all the way into the back of the horn. I don't see how to open the horns and redo the wiring... Does anyone have any suggestions on how to open these horns? Might be easier to just find replacements.
Thanks
old46ford is offline   Reply With Quote
Old 01-31-2017, 09:21 AM   #2
Gary in La.
Gary in La.'s Avatar
Default Re: Horn question - 46 coupe
The covers are just a press fit on to the body. Look along the edge of the cover where it meets the body and you will see some small indentations. Take a thin blade and gently pry up on the cover. It should just pop off.
Gary in La. is offline   Reply With Quote
Old 01-31-2017, 09:22 AM   #3
19Fordy
19Fordy's Avatar
Here's a horn pictorial.
Old 01-31-2017, 09:23 AM   #4
19Fordy
19Fordy's Avatar
You may have to drill out some type of rivets. Or, perhaps you can slide in a piece of heat shrink tubing where the OEM wire enters the horn. Here's a pictorial.
OPPS!
PLEASE DELETE
Old 01-31-2017, 09:50 AM   #5
old46ford
Thank you. I was just thinking of using heat shrink tubing... good ideas
Old 01-31-2017, 11:18 AM   #6
edhd58
edhd58's Avatar
Mine are like those and had screws holding the covers on.
edhd58 is offline   Reply With Quote
Old 01-31-2017, 11:26 AM   #7
old46ford
yeah, mine appear to have rivets holding it together. Not screws...
Old 01-31-2017, 12:25 PM   #8
brake1000
brake1000's Avatar
Don't drill or grind off the rivet head, that's just the head of the bolt, pop off the cap. The wire is soldered on a post on the inside.
brake1000 is offline   Reply With Quote
Old 01-31-2017, 01:31 PM   #9
FortyNiner
FortyNiner's Avatar
There is a single screw on the end of the cap but the cap itself is removed as Gary indicated. No need to remove rivets.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
