Old 02-10-2021, 10:16 PM   #1
jw hash
jw hash's Avatar
Default penrite lube
does anyone in the US sell Penrite steering box lube?
jw hash is offline   Reply With Quote
Old 02-10-2021, 10:52 PM   #2
CWPASADENA
CWPASADENA's Avatar
Default Re: penrite lube
Restoration Supply in Escondido, Ca.
Restorationstuff.com
[email protected]
800 306-7008
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-11-2021, 10:01 AM   #3
jw hash
jw hash's Avatar
thank you CW
John
Old 02-11-2021, 02:01 PM   #4
7_Zero
7_Zero's Avatar
It is mentioned in these two threads that the Penrite is 00 grease. I picked up some 00 grease at Tractor Supply for $5 and am pleased so far. This could be a cheaper alternative to the Penrite.
https://www.fordbarn.com/forum/showt...hlight=Penrite
https://www.fordbarn.com/forum/showt...=278772&page=3
7_Zero is offline   Reply With Quote
Old 02-11-2021, 06:09 PM   #5
hudson32700
I use John Deere corn head grease. About $4.50 a tube where I live in Illinois.
Works great.
hudson32700 is offline   Reply With Quote
Old 02-11-2021, 06:54 PM   #6
Synchro909
Synchro909's Avatar
I've found cornhead grease to be too susceptible to heat. It goes too liquid when it gets warm and the steering box is right next to the exhaust.
Old 02-11-2021, 07:16 PM   #7
Patrick L.
Patrick L.'s Avatar
I guess that would make sense in the Land Down Under.
Old 02-11-2021, 08:05 PM   #8
1952henry
1952henry's Avatar
Lube from tractor supply is exact same stuff as Pennritw at 1/4 the price.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 02-11-2021, 11:25 PM   #9
Synchro909
Synchro909's Avatar
Which tractor lube?
Old 02-12-2021, 09:09 AM   #10
Bob from Northport
Bob from Northport's Avatar
This tractor lube at Tractor Supply
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 02-12-2021, 10:35 AM   #11
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
John, not to hi-jack your thread however just to keep muddy waters stirred up a bit, HERE is some of my thoughts on the subject of grease in a steering gearbox. Maybe y'all will agree or disagree??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-12-2021, 11:01 AM   #12
Curtis in MA
Is it just terminology?
I think of "lube" like 600w oil and "grease" like I use in a grease gun.
Does Penrite make both?
Curtis in MA is offline   Reply With Quote
Old 02-12-2021, 11:32 AM   #13
Ruth
Penrite makes numerous products. Penrite Steering Box Lube is 1200w.
Ruth
Old 02-12-2021, 05:11 PM   #14
Synchro909
Synchro909's Avatar
It can't be very thick if it comes in a bottle with a neck like that. I'm sure the Penrite steering box lube I use is thicker than that would be.
Old 02-12-2021, 05:34 PM   #15
Bob from Northport
It is NOT. It is the same because I have both in the shop
Bob from Northport
Northport, Michigan
Old 02-12-2021, 07:15 PM   #16
Synchro909
Synchro909's Avatar
Must take a long time to get it out of the bottle, especially in cold weather.
Old 02-12-2021, 07:41 PM   #17
alexiskai
alexiskai's Avatar
I think many folks do like I do and heat it up via a pot of hot water before filling.
Old 02-13-2021, 09:36 PM   #18
Gene F
Gene F's Avatar
May I ask, why do we even think we need to change the lube from the 600W to begin with?
Old 02-13-2021, 10:29 PM   #19
CWPASADENA
CWPASADENA's Avatar
In a lot of cases, the 600W will leak out, Penrite and other thicker lubes do not.
Chris W.
Old 02-14-2021, 11:48 AM   #20
Gene F
Gene F's Avatar
Hmmmm. My 7-tooth used to leak, but not any more. The tube up the middle was added, and the correct sector shaft bushings were installed. Not the water pump bushings some vendors sell.
FYI: my car had grease in the steering box when I got it.
