Old 01-25-2020, 11:23 AM   #1
denis4x4
denis4x4's Avatar
Default ARP head studs
Picked up an ARP catalog at the GNRS and see that they have a head stud kit for the Model A with polished SS acorn nuts and washers. Part number is 151-4002.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is online now   Reply With Quote
Old 01-25-2020, 12:02 PM   #2
Jim Brierley
Default Re: ARP head studs
Does the catalog show the price? ARP are the best but a bit on the expensive side.
Old 01-25-2020, 09:40 PM   #3
CarlG
CarlG's Avatar
That kit # hasn't hit the on-line catalog yet.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-29-2020, 08:01 PM   #4
Chad Marchees
Weird, I have a saved electronic copy of a 2017 catalog with it in it, and I have been looking at it online in their 2020 catalog for at least the last 2 weeks now. I saw it and pointed it out to a friend of mine.
*edit* I emailed Summit Racing to get pricing on the kit as I don't see it listed anywhere online.
Chad Marchees is offline   Reply With Quote
Old 01-30-2020, 12:26 AM   #5
johnneilson
Might also try Reds Headers, they carry ARP now also.
http://www.reds-headers.com/html/contact_us.html
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is online now   Reply With Quote
Old 01-30-2020, 11:39 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
As the sud stiffness increases, the stress in the block threads increases, and fatigue life is adversely effected. Why do you need studs intended for high performance engines?
Bob Bidonde
Old 01-30-2020, 11:56 AM   #7
Jim Brierley
Because I run high performance engines!
Old 01-30-2020, 08:05 PM   #8
Pete
Pete's Avatar
> We are not concerned with stud stiffness, we are using them in tension and thread form shear.
> The stress on the block threads will remain the same as long as the torque value is the same and the thread form is the same.
Fatigue life of the BLOCK threads is NOT affected by changing the material the stud is made of. That changes ONLY with torque value, thread form and number of cycles the system goes through.
>In a STOCK engine, you don't, unless you get ham fisted with the torque wrench.
Old 01-30-2020, 11:30 PM   #9
johnneilson
Originally Posted by Pete View Post
You would be amazed at how much damage happens when someone thinks they need to torque the head studs to anything higher than 55ft/lbs "to contain high compression heads"
The one that always gets me, mill the head for higher compression and then assemble with two gaskets. Does even more damage.
Old 01-30-2020, 11:36 PM   #10
PalAl
PalAl's Avatar
Ya have to admit, that was funny! Well it made me laugh.....
Love this Forum
PalAl is offline   Reply With Quote
Old 01-31-2020, 12:51 AM   #11
Pete
Pete's Avatar
There are applications where more is better and too much is not enough.
I bought a B block with NO cracks once for 10 bucks. It had every head stud either broken off or stripped out of the block. Easy fix for me. No so much for others. I sleeved each hole with a tapered steel plug .750 on the OD.
The head had 2 o-ring grooves and the block had one that sat in the middle of the head ones. The stud spot face surfaces in the head were enlarged for bigger thicker washers. The head was installed with a solid copper gasket .030 thick.
The studs were made from SAE4340M and heat treated to 40RC. The washers were 1.4 inch dia and .250 thick 4340.
The off the shelf hard high nuts were torqued to 100 ft. lb.
This FLATHEAD engine never blew a head gasket and it went on to win the top fuel 4 cylinder class at the national championship drags running 97% nitroethane and 3% stuff.
It would have been nice to have had one of John's 5 main cranks and girdle back then.
Old 01-25-2021, 02:06 AM   #12
alexiskai
alexiskai's Avatar
Resurrecting this thread to ask: has anyone actually purchased ARP kit 151-4002? Is it real? I'm curious what their torque instructions were.
Old 01-25-2021, 08:42 AM   #13
Bob Bidonde
I agree that torque increases the stress in cylinder block threads, but so to does the stud stiffness. Try a rubber bolt analysis and vary the stud stiffness.
Bob Bidonde
Old 01-25-2021, 10:01 AM   #14
denis4x4
denis4x4's Avatar
Been running ARP studs, washers and acorn nuts for 3 years. I have the B-F Super head and the torque is 60 pounds
Old 01-25-2021, 10:49 AM   #15
alexiskai
alexiskai's Avatar
Denis, was 60 lbs ARP’s spec or Larry Brumfield’s?
Old 01-25-2021, 11:58 AM   #16
alexiskai
alexiskai's Avatar
Never mind, I asked ARP and they said:
“I’m sorry we haven't released that kit , it is still being tested with R&D.”
So there you go, no official guidance yet and no one has purchased the kit (officially).
Old 01-25-2021, 12:19 PM   #17
johnneilson
I doubt that ARP will release a stud set for the Model "A", seriously there are bigger fish to fry. Also it should be noted that there are too many different heads available for the Mod"A", and will require many different set options.
Victor, Red's Headers offers ARP studs, you will probably need to measure and provide the lengths you wish.
As for suggested torque, 55 ft/lbs is all that is required. I have heard of people running more with higher compression heads but the physics do not change, over torquing will cause problems. I do believe that Larry Brumfield used 60 ft/lbs, that is not excessive.
The benefit is the ARP stud/nut combination will give consistent clamping for the applied torque and will not fatigue/yield like other questionable fasteners.
As to my experience with them, I use nothing else. From street applications up to race with 300 HP, in the stock locations.
John
Old 01-25-2021, 01:25 PM   #18
CarlG
CarlG's Avatar
When I bought ARP studs, I had to buy individual studs. No one I talked to there even knew what a Model A Ford was.
Alaskan A's
Old 01-25-2021, 03:53 PM   #19
duke36
Brumfield recommendations at 60 to 65 '#.
Old 01-25-2021, 04:49 PM   #20
denis4x4
denis4x4's Avatar
Full disclosure: An ARP employee did some work on several of my cars during vacations in Durango and created a Model A kit that was shipped to me.
