Old 07-16-2021, 06:19 PM   #1
midgetracer
midgetracer's Avatar
Default Low oil pressure in 60hp flathead
I have a 39 60hp flathead in a Model A roadster. Oil pressure drops to 10 psi when it warms up. When I installed it, I used an electric fuel pump. I did not put the fuel pump push rod in the engine. Could the low pressure be due to the absence of the push rod and the oil pressure leaking from the push rod guide?
If so what is the best way to plug the guide so I don't have the push rod just bouncing in the guide? Any help will be greatly appreciated. Normally I post on the A site, but this is a question for flathead experts.
midgetracer is offline   Reply With Quote
Old 07-16-2021, 06:41 PM   #2
Kube
Kube's Avatar
Default Re: Low oil pressure in 60hp flathead
10# at idle when it warms or at 50MPH?
Old 07-16-2021, 07:20 PM   #3
midgetracer
10 psi at idle and at 50 mph when warm. Maybe as low as 7psi at idle.
Old 07-16-2021, 07:22 PM   #4
KiWinUS
KiWinUS's Avatar
More info on engine please. Rebuilt. Old. Junker Real race midget engine or what.
KiWinUS is online now   Reply With Quote
Old 07-16-2021, 07:27 PM   #5
midgetracer
Rebuilt stock engine with two 81 carbs and aluminum eddie meyer heads.
Old 07-16-2021, 07:32 PM   #6
Kube
Kube's Avatar
So, if I am to understand correctly, you have about 10# at idle AND at 50MPH?
Old 07-16-2021, 07:41 PM   #7
midgetracer
Yes, maybe a bit lower at idle. Hard to read gauge at less than 10psi.
Old 07-16-2021, 10:23 PM   #8
drolston
drolston's Avatar
The fuel pump push rod bushing does not have full oil pressure, but it probably should be closed off.
10 psi at idle is fine. Not at 50 mph. Something is fishy. Maybe check with a mechanical oil pressure gauge.
Is the oil pressure relief on a 60 the same as the 85? Could be
Old 07-18-2021, 12:34 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
30 lbs pressure at 3200 rpm is spec in service bulletins
the fuel pump push rod is open to crankcase next to cam bearing has no involvement with oil pressure.
There is a pressure relief valve under the intake manifold, i have seen the spring broken
What attention was paid to the oil pump and cam bearings during the "rebuild"?
Old 07-18-2021, 09:10 AM   #10
midgetracer
new cam bearings and new oil pump gears. I will check pressure valve next.
Old 07-18-2021, 11:46 AM   #11
Kurt in NJ
Kurt in NJ's Avatar
With the pan off you could do a "drip test", with a pressure pot --pre oiler put oil under pressure into the gauge port then watch the leakage out the bearings anything more than drips out of each bearing is too much---this is a way to determine the loss of pressure without taking everything apart ,it is outlined in the Ford engine rebuilding book as a way of eliminating oil pressure problems after delivery of rebuilt engines
Old 07-18-2021, 12:48 PM   #12
KiWinUS
KiWinUS's Avatar
Oil gallery plug installed behind cam gear?
Old 07-18-2021, 05:10 PM   #13
midgetracer
Kurt, Thank you. this is a good thing to try. Also thanks KiWinUS. I will check all of this when the temp goes down a bit. It has been close to 100F every day lately and my shop has no AC.
