Old 02-06-2021, 10:01 AM   #21
Conaway2
Conaway2's Avatar
Default Re: Pic of #4 rod/bearing.
The bearing doesn’t look bad. As others have suggested, clean it up and see if you can set the correct clearance. I like to use Plastigage for this.
Jim
Conaway2 is offline   Reply With Quote
Old 02-06-2021, 10:43 AM   #22
Jack Shaft
I'm going deeper on the babbit question.I agree with the antimony content and shiny/harder theory...its not an oxidation result that I can tell what I know about oxidation and corrosion is it occurs from the outside -in and ultimately affects the surface...in this case the surface is perfect.
This block has been repaired ,it cracked 2&3 exhaust seat to cylinder.The repair work is beautiful and precise..ill shoot some more pictures today.the previous owner/ builder was a master machinist at Aero-jet,the rocket/ space research/defense outfit..I wonder if he used an uncommon /exotic babbit design.
Jack Shaft is offline   Reply With Quote
Old 02-06-2021, 11:06 AM   #23
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
That's lead based babbitt from the pictures you've shown of the B rod.
If it was tin/nickel antimony it wouldn't turn dark and dull as lead does.
It would still be bright as the example I have included.
J and M Machine is offline   Reply With Quote
Old 02-06-2021, 11:09 AM   #24
katy
katy's Avatar
What I have witnessed is the darker the babbitt the softer it is (higher lead content?).
Genuine Ford babbit had no lead in it. Other babbits vary.
Old 02-06-2021, 11:27 AM   #25
Jack Shaft
Its not a high lead content that i can tell,lead scores easy,this is very hard.
Old 02-06-2021, 12:50 PM   #26
hardtimes
hardtimes's Avatar
Hey John,
Thanks !
I didnt get IT then, and dont know about now.
I think that I heard what I thot you said, but not sure that what you said is not what I meant to hear. Did I tell you I have dyslexia.
So, Im out in shed with flashlight.... in PJs...with ice pick in hand !
She , standing on porch..100 ft away, says the samhell are you doing !! Scratching the babbitt !
WHAT are you doing to the baby ???? Come in, your oatmeal is ready ! Yum..oatmeal... ok.
Did you forget to take you medicine.. again ?
No no, John said to scratch...forget it.
BTW... it scratched easily.. the babbitt.
hardtimes is offline   Reply With Quote
Old 02-06-2021, 01:04 PM   #27
nkaminar
nkaminar's Avatar
The oxidation is only surface deep. It probably doesn't go any deeper than a few molecules.
Old 02-06-2021, 01:20 PM   #28
Jack Shaft
Agreed Neil but its consistent,the coloration has no deviation...Hopefully I can get back on it today and give a better example of what it is.
Old 02-06-2021, 04:53 PM   #29
hardtimes
hardtimes's Avatar
Ok, so I just used crocus cloth as you suggested. Yeah, some improvement in appearance !
I’m familiar with this idea/process !
Dont think I can do maybe one a day. You old enough to get raspberry marks, or to know what they are ?
I got plenty today by , just from just one throw. That and arthritis and done for the week now. She says ... work smarter !!
I say hiring some yute to do...is smarter.
Anyway, I’ll geterdone.
Old 02-06-2021, 06:37 PM   #30
1crosscut
1crosscut's Avatar
Is this an engine that has been run in the past or is it a "fresh" rebuild. If it has been run and the babbit looks like that I wouldn't loose much sleep about running it.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 02-06-2021, 07:13 PM   #31
Jack Shaft
Get a die grinder and some wool pads,use jewelers rouge it will polish like a mirror...works good on stainless too..crocus cloth too much work..
Old 02-07-2021, 02:53 AM   #32
hardtimes
hardtimes's Avatar
I agree with your assessment !
ITve been working at it hard most days. If I had a little help, I’d have it running. So far, I’ve been able to make great progress. I have stop for couple days, to give my swollen hands rest.
This engine had good work done to it, who knows when. It obviously was not given proper care/maintenance, and stored that way years ago, IMO.
I will make upgrades and get it running ....soon.
If receive lemon, make lemonade !!
Old 02-07-2021, 03:06 AM   #33
hardtimes
hardtimes's Avatar
Thank you !
So is lead still used or is this real old babbitt ?
UPDATE:
Rods 1,2and 3 are really nice babbitt and journals...bright/shiny !!
