Old 12-21-2011, 11:42 PM   #1
Ford guy 2
Default Generator
Newbe Question , I have overhauled my 31 generator i put in new field coils new brushes cleaned it on the inside and outside new bearings it is like new, I have tested for shorts with my meter and no shorts.So when i hooked the generator up and ran the engine my amp meter is not showing a charge i have taking the generator apart 3 times now and i just can not find what is wrong with it , i am using a cut out with a diode installed and it worked before i did the work on the generator, Please help thankyou Pete.
Ford guy 2 is offline   Reply With Quote
Old 12-22-2011, 12:01 AM   #2
sethkestenbaum
sethkestenbaum's Avatar
Default Re: Generator
Did you polarize the generator?
sethkestenbaum is offline   Reply With Quote
Old 12-22-2011, 12:12 AM   #3
Ford guy 2
No i did not polarize the generator how do you do that , Pete
Old 12-22-2011, 01:21 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Simply apply battery voltage to the output stud on the generator to polarize it.
The easiest way to do this is to jump a short wire across the two cutout terminals.
Old 12-22-2011, 07:43 AM   #5
Tom Wesenberg
One more thought, since you have a diode cutout, if the battery is installed with the wrong ground polarity you will have no output, even if you polarize the generator. Also the battery would be connected to the generator at all times and the generator would soon overheat. Hopefully you have a positive ground battery and the correct polarity diode cutout for it.
Old 12-22-2011, 07:51 AM   #6
RonC
RonC's Avatar
To polarize you can momentarily jump (or flash as they call it) the two cut-out terminals together with the handles of a pair of pliers.
RonC is offline   Reply With Quote
Old 12-22-2011, 09:14 AM   #7
amedic
Will your generator "motor" when you hook it up to a battery? A gen. that is working properly will run slowly, just like a dc motor when you hook it up to a battery. It should be smooth... and should draw around 6-7 amps. If it will not do this then will need to go back and check things again. Did you growl the armature?
amedic is offline   Reply With Quote
Old 12-22-2011, 09:26 AM   #8
jimvette59
jimvette59's Avatar
Hi just thinking, did you turn down the commutator and run in the brushes.
jimvette59 is offline   Reply With Quote
Old 12-22-2011, 08:56 PM   #9
Ford guy 2
I just did the polarize thing and that did not work thanks for all your help Pete
Old 12-22-2011, 09:30 PM   #10
Tom Wesenberg
Are you checking for voltage at the generator output post? Or at the cutout output terminal?
Sometimes the cutout contacts are dirty and don't pass the current, even they they close. Actually, it's best to check both places and compare the readings. There should be less than .1 volt difference.
