Old 03-11-2020, 05:23 AM   #1
chuckwp
Default Repairing 1935 tail light stands.
I have a '35 tail light stand with both studs broken and looking for ideas on how to repair it. My This is not going to be re-painted as we are trying to preserve the patina. Since the studs are sort of captive in the base, it is not possible to drive them out with out taking the thing apart. So, since they are essentially carriage bolts, my idea is to cut slots in the base and try to slide them out.
Anyone dealt with this? Have a better idea?
chuckwp is offline   Reply With Quote
Old 03-11-2020, 06:22 AM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: Repairing 1935 tail light stands.
Quickfix would be a stud with different size threads...drill and tap the broken off part with a smaller diameter...
Old 03-11-2020, 06:57 AM   #3
4 MAINS V8
4 MAINS V8's Avatar
Carriage bolts are spot welded to base. I would carefully grind off stud flush with base and then drill through the centre of stud 5/16, insert a new bolt and secure with a dab of mig, therefore preserving the paint.
4 MAINS V8 is offline   Reply With Quote
Old 03-11-2020, 08:14 AM   #4
chuckwp
I was thinking about that as well. I agree that it is a better option and will give it a go.
Old 03-11-2020, 08:32 AM   #5
uncle buck
uncle buck's Avatar
This is what I have done in the past and was an easy fix. Quite often when you grind it flush the original head can be knocked out allowing you to use a carriage bolt
uncle buck is offline   Reply With Quote
Old 03-11-2020, 12:22 PM   #6
CA Victoria
CA Victoria's Avatar
Is there enough bolt left to use a nut and all-thread w/ thread locker to extend the stud?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 01-09-2021, 08:03 AM   #7
chuckwp
Fixed. Ground bolts flush with base, drilled out and tapped to 1/4" Then used studs with washers and nuts.
