06-04-2017, 02:16 PM | #1 |
Halibrand quick change
In the never ending saga of my Halibrand V8 quick change.
When Rich owned Halibrand and built my rear two problems have surfaced in the assembly. The first is the closed tube driveshaft had to have the spline switched from 10 tooth to 6 and the other and current problem is that the shaft is not drilled to pin the driveshaft to the lower shaft. I'm sure it's hard and I'm sure the shaft has to be pinned. Any ideas. Thanks Pete Sent from my iPad using Tapatalk |
06-04-2017, 04:20 PM | #2 |
Re: Halibrand quick change
