Old 01-01-2013, 12:16 AM   #1
oldmanandakid
oldmanandakid's Avatar
Default 6 to 12 Volt Voltage Booster Positive Ground Converter
Does anyone have a schematic for a 6 to 12 Volt Voltage Booster Positive Ground Converter? It seems like something that could be wired up at home. Maybe?
oldmanandakid is offline   Reply With Quote
Old 01-01-2013, 10:44 AM   #2
Paul in Colorado
Paul in Colorado's Avatar
Default Re: 6 to 12 Volt Voltage Booster Positive Ground Converter
A complete one is available on eBay for about $60. It is usually posted under "Ford Model A"
Paul in Colorado is offline   Reply With Quote
Old 01-01-2013, 11:04 AM   #3
Purdy Swoft
Purdy Swoft's Avatar
I'm not sure exactly what you mean. I converted to 12 volt positive ground and it is very simple. Install 12 volt battery and connect the battery cables positive ground. No wires will need to be reversed or changed. You will need a coil rated at 3.0 OHM or you can use the original coil with a ballast resistor . The bulbs will need to be changed to 12 volt. Voltage reducers are available for 6 volt horns and electric wiper motors. I use a repro 12 volt ahooga horn and like it .The repro 12 volt horn doesn't have that sick cow sound . The original generator and starter works great on 12 volt without any modification. I use a 12 volt positive ground Fun Projects voltage regulator in place of the cutout. An original cutout in good condition will work just as well on 12 volt but won't give voltage regulation. This is a simple, straight foward conversion that gives best of both worlds performance.
Old 01-01-2013, 12:03 PM   #4
29ModelA
29ModelA's Avatar
I believe I have seen what he is talking about in the catalogs. It is a little board that connects to the 6v battery and steps the voltage up so you can have a 12V cigarette lighter plug in the car, or run some 12v accessories. It is not to convert the car to 12v. I tried finding it on Snyders website but wasn't having any luck.
1929 Model A Barn find. California car, just a few more parts to find.
Interior, steering box (rebuild), and I am sure much more!
29ModelA is offline   Reply With Quote
Old 01-01-2013, 01:08 PM   #5
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
OR do you mean an Inverter???? they are 59.00 on ebay and work GREAT!
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 01-01-2013, 02:32 PM   #6
29ModelA
29ModelA's Avatar
I believe this is what he is talking about.
Power Converters
These units convert your Model A's 6-volt positive ground systems power to 12-volt negative ground so you can power a CB, radio, or any other 12-volt accessory. 2.5 amp output. U.S.A. $99.95
http://www.snydersantiqueauto.com/2838
For a hundred bucks I don't know that I would bother trying to make it, especially USA made.
Old 01-01-2013, 02:58 PM   #7
Tom Endy
Tom Endy's Avatar
Your original question is, does anyone have a schematic of an inverter. I suspect you have an electronics background and want to build one. I can't help you in that area. However, I built up an assembly using the inverter shown above that Snydere sells for about $100. Bratton sells the same thing, and that was where I bought mine.
I wrote an article for a club newsletter about the assembly and installation.
To view the article go to www.ocmafc.com. On the menu at left scroll to "tech articles" and click. It will bring up the tech page. At the top is my name, click on it and a new menu will come up. Scroll to "power inverter" and click. You are welcome to down load it, save it, and print it out.
The assembly is installed in my Victoria, which has a 6-volt positive ground electrical system. The assembly is mounted under the dash rail on the right side. It is mostly out of sight and is easy to use. It has been there for several years now without a problem. I can run both a GPS and charge my cell phone with it.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 01-01-2013, 03:26 PM   #8
msmaron
msmaron's Avatar
Here you go,,,,this is what you want
http://www.ebay.com/itm/Ford-Model-F..._Video&vxp=mtr
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 01-01-2013, 04:48 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
I had one in my MG to convert 12+ ground to 12V - ground, it would also do 6V to 12V, not much inside that would be hard to duplicate except the transformer
http://www.ebay.com/itm/6-TO-12-VOLT...9c7f4e&vxp=mtr
and --- http://www.ebay.com/itm/Ford-Model-A...560643&vxp=mtr
Old 01-01-2013, 05:40 PM   #10
msmaron
msmaron's Avatar
Kurt are they both the same?.
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
Old 01-01-2013, 09:17 PM   #11
oldmanandakid
Thanks Guys.....Tom I got the download and another good site to bookmark.....Jerry
Old 01-01-2013, 09:32 PM   #12
jmeckel
jmeckel's Avatar
These devices use a isolated 2 stage switching supplies. That way they can up convert to a higher voltage / high frequency and then rectify and regulate it back down to 12 volts DC and tie the negative side of the output to frame of the car ground so you do not need to isolate anything. There are plans on the Internet for these type of switching supplies you would need to do component design to your specs. I decided it was way to much work and just purchased a $50 unit from Ebay, and mounted it like Tom E's tech bullitins. Works great.
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
